can somone tell me what this is for?
Old Feb 4, 2005 | 08:33 AM
b16crx0062004's Avatar
Default can somone tell me what this is for?
it is on a honda crx hf 89 near the hood prop bracket there is a 2 wire clip that is capped off 1 wire is brown with blue dotts and the other is green with a white stripe? anybody know?
Old Feb 4, 2005 | 08:38 AM
SuperSteve737's Avatar
can you get a pic?
Old Feb 4, 2005 | 08:40 AM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: (SuperSteve737)
It is a jumper for setting the base ignition timing..
You jump it to let the ecu know you are doing this
so it does not try to alter it..
Old Feb 4, 2005 | 08:47 AM
Crx Jimmy's Avatar
Default Re: can somone tell me what this is for? (b16crx0062004)
yeah the older crx's have it there, 90 and later have it by the ecu
Old Feb 4, 2005 | 10:46 AM
Default Re: (88DXCRX)
thanks. yah ever since i have owned the car i was wondering what it was for
Old Feb 4, 2005 | 01:39 PM
88DXCRX's Avatar
Default Re: (b16crx0062004)
http://www.binghamtonlife.com/...8.jpg
Old Feb 4, 2005 | 02:41 PM
HatchBox's Avatar
Skoobie no more...
where is that jumper clip on the 90 civic hatchs?
Old Feb 4, 2005 | 02:59 PM
88DXCRX's Avatar
Default Re: (HatchBox)
It should be in the area pictured..
Passenger side kick panel under the dash
(This pic is from my car which is an '88 so it is in the engine compartment..)
Old Feb 4, 2005 | 03:14 PM
HatchBox's Avatar
Skoobie no more...
88DXCRX = the man
Old Feb 4, 2005 | 03:50 PM
bucketheadCRX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HatchBox &raquo;</TD></TR><TR><TD CLASS="quote">88DXCRX = the man </TD></TR></TABLE>word
Old Feb 4, 2005 | 05:38 PM
Blaze45's Avatar
Brrraaaap!
Default Re: (buckethead36)
88DXCRX for mod with EL Vap!
Blaze
Old Feb 13, 2005 | 04:30 PM
VashTheStampede's Avatar
No tears. Only dreams, now.
Default Re: (Blaze45)
Anyone want to tell me the difference/advantages of ignition timing over cam timing? Or are they pretty much the same? That is to say, could I advance the igntion timing 2 degrees on my stock Si and run 93 Octane for more power? Or am I sounding like a retard?
Old Feb 13, 2005 | 05:47 PM
DocSean's Avatar
Default Re: (VashTheStampede)
Ignition timing and cam timing are two different things as far as I understand. I believe ignition timing is pretty dependant upon mods...you can't just add 2 degees and get more power.
This is how I see the 2 (I could be wrong)
Ignition timing is the relation of the actual spark in relative to top dead center.
Cam timing is the relation of the rotation of the camshaft in relative to top dead center.
Old Feb 23, 2005 | 04:11 AM
b16_madman's Avatar
Default Re: (spankjelly)
holy crap, now i know what the yellow plug is for, hope my timing isn't fawked then, b/c i set it to 17* of advance!
Old Feb 23, 2005 | 04:33 AM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VashTheStampede &raquo;</TD></TR><TR><TD CLASS="quote">That is to say, could I advance the igntion timing 2 degrees on my stock Si and run 93 Octane for more power?</TD></TR></TABLE>
You wouldn't "gain" the power, so much as shifting it from elsewhere in the curve . . .
Old Feb 23, 2005 | 07:25 AM
Default Re: (Targa250R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">You wouldn't "gain" the power, so much as shifting it from elsewhere in the curve . . .</TD></TR></TABLE>
Shifting it low would be nice, but shifting the TQ up high would mathematically give you more HP since it is a function of TQ.
OBD0 OBD0 OBD0 OBD0 OBD0 OBD0 OBD0 OBD0 OBD0 OBD0 OBD0 OBD0 OBD0 OBD0 OBD0 OBD0 OBD0 OBD0 OBD0 OBD0 OBD0 OBD0 OBD0 OBD0 OBD0 OBD0
EF8 EF8 EF8 EF8 EF8 EF8 EF8 EF8 EF8 EF8 EF8 EF8 EF8 EF8 EF8 EF8 EF8 EF8 EF8 EF8
Old Feb 23, 2005 | 12:11 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VashTheStampede &raquo;</TD></TR><TR><TD CLASS="quote">Shifting it low would be nice, but shifting the TQ up high would mathematically give you more HP since it is a function of TQ.</TD></TR></TABLE>
Right.
And shut up
Old Feb 23, 2005 | 12:56 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">Right.
And shut up </TD></TR></TABLE>
lmao...
instrument
Oct 25, 2014 12:57 PM
suspirocrx
May 2, 2012 09:10 AM
RSZero1
Jan 17, 2007 12:49 PM
AJxr
Nov 22, 2005 11:51 PM
