'97 Integra Wire Colors/Locations?
Old Jan 15, 2002 | 02:46 PM
Weston's Avatar
Default '97 Integra Wire Colors/Locations?
Hello, I am going to install an alarm on my '97 Integra LS, but am having trouble finding the correct wires to tap into. I know most of the wire colors and approximate locations, but I've found several cases of 2 or more unrelated wires that have the same colors and are near each other. I need to find the wires for: door lock output, door unlock output, parking light output, horn switch output (wire between the horn switch and it's relay), door open input, and ignition active input (anything that's powered when the key in in the start/run position). I also need to find an always-hot positive wire, but that should be pretty easy. I have a good idea where many of the wires are, but I would really like to make sure they are the right wires before I do the cut-and-test method.
Also, does anyone have any ideas where to mount the alarm's siren? I've heard behind the left headlight or over in some open spot in front of the battery and strut tower. So far, behind the left headlight is sounding the best, but I'd still like to hear other ideas.
Thanks!
Old Jan 15, 2002 | 04:39 PM
flotsamm's Avatar
Default Re: '97 Integra Wire Colors/Locations? (Weston)
I found this on the 'net.. hopefully it'll help. The tabs are off but you can clean that up with the spacebar.
*Attn: Mods- If this isnt allowed material please delete and accept my appologies*
YEAR: 1997 MAKE: Acura MODEL: Integra STYLE:
| ITEM | WIRE COLOR |POL | WIRE LOCATION |
| 12V |white | + |ignition harness |
| STARTER |black/white | + |ignition harness |
| IGNITION |black/yellow | + |ignition harness |
| ACCESSORY |yellow | + |ignition harness |
| POWER LOCK |black/white | - |drivers kick panel *2 |
| POWER UNLOCK |black/red | - |drivers kick panel *2 |
| PARKING LIGHTS + |red/black *3 | |grn plug above fusebox |
| PARKING LIGHTS - |green/yellow | |factory alarm (if equipped) |
| HEADLIGHTS |red/wht (low) 12awg | + |steering column |
| DOOR TRIGGER |lt. green/red *4 | - |drivers kick panel *2 |
| DOME SUPERVISION |use door trigger | | |
| TRUNK/HATCH PIN |green | - |*6 |
| HOOD PIN |yellow/red | - |drivers kick panel |
| FACTORY ALARM ARM |factory remote only | | |
|FACTORY ALARM DISARM |factory remote only | | |
| TACHOMETER |blue | |distributor *1 |
| SPEED SENSE |orange | |instrument cluster |
| BRAKE WIRE |green/white | + |brake switch |
| HORN TRIGGER |gray or blu/grn | - |steering column |
| WIPERS |blue & blu/yel *5 | - |steering column |
| LF WINDOW UP/DOWN |red/blu - red/yel | A |in drivers door |
| RF WINDOW UP/DOWN |blu/yel - blu/grn | A |in drivers door or dkp |
| LR WINDOW UP/DOWN |green - grn/yel | A |in drivers door or dkp |
| RR WINDOW UP/DOWN |yel/grn - yellow | A |in drivers door or dkp |
| SUN ROOF OPEN/CLOSE |grn/red - grn/yel | A |sun roof switch |
| RADIO 12V |white/blue | + |radio |
| RADIO GROUND |black | - |radio |
| RADIO SWITCH |yellow/red | + |radio |
| RADIO ILLUMINATE |red/black | + |radio |
| POWER ANTENNA |yellow/green | + |radio |
| LF SPEAKER |blu/grn - gry/blk | |radio |
| RF SPEAKER |red/grn - brn/blk | |radio |
| LR SPEAKER |blu/yel - gry/wht | |radio |
| RR SPEAKER |red/yel - brn/wht | |radio |
NOTES:
*1 Also found in a 16 pin white or gray plug to the left of the fusebox.
*2 In the larger of two attached gray plugs in the lower kick near the
firewall. If equipped with cruise control, the plugs are behind the
module. To access, remove the lower bolt on the bracket holding the module
and pull it up out of the way. The lock wires test only with the
passenger lock and unlock switch.
*3 Also a male blade terminal is available in fuse box.
*4 Looks like 14 ga.wire but mostly insulation.
*5 Use both and diode isolate each.
*6 12 pin blue plug on top center of fusebox.
(c) 1994-2002 Directed Electronics, Inc. All Rights Reserved
IMPORTANT: This wiring information is being provided free of charge on
an "AS IS" basis, without any representation or warranty. It is your
responsibility to verify any circuit before interfacing with it using
a digital multimeter. Directed Electronics, Inc. assumes no responsibility
with regards to the accuracy or currency of this information. Proper
installation in every case is and remains the responsibility of the
installer. DEI assumes no liability or responsibility resulting from an
improper installation, even in reliance upon this information.
Old Jan 15, 2002 | 06:15 PM
Weston's Avatar
Default Re: '97 Integra Wire Colors/Locations? (flotsamm)
Cool, that's exactly what I was looking for. I've only been able to find incomplete, inaccurate, and/or vauge charts like that before. But, that one looks like it has everything I'll need. Thanks!
Old Jan 29, 2002 | 01:14 AM
95gsr's Avatar
how were you able to find that i need the same but for a 98 jeep cher.sport
Old Feb 1, 2002 | 09:50 PM
o_Rage_o's Avatar
Default Re: '97 Integra Wire Colors/Locations? (95gsr)
JEEP CHEROKEE 2000 (should be the same)
NOT INTEGRA
12V Pink/Black Ignition Switch
Starter Yellow Ignition Switch
Ignition 1 Dark Blue Ignition Switch
Ignition 2 NA Ignition Switch
HVAC 1 Black/Orange Ignition Switch
HVAC 2 NA NA
Accessory Black/White Ignition Switch
VATS none none
Hot Side Brake Pink/Blue At Brake Switch
Cold Side Brake White/Tan At Brake Switch
Tach Gray At Coil
Lock Orange/Purple Left Kick Panel
Lock Type 3 wire negative
Unlock Pink/Purple Left Kick Panel
Unlock Type 3 wire negative*
Trunk Release NA NA
Trunk Release Type NA
Head Lamp Light Green At Switch
Head Lamp Type Positive
Park Lamp Black/Yellow At Switch
Park Lamp Type Positive
Door 1 Yellow under dash light
Door 1 Type Negative
Door 2 NA NA
Door 2 Type NA
Door 3 NA NA
Door 3 Type NA
Trunk Pin Uses Door Trigger see Door 1
Trunk Pin Type Negative
Horn Black/Red Steering Column
Horn Type Negative
OEM Arm NA NA
OEM Arm Type NA
OEM Disarm NA NA
OEM Disarm Type NA
Sense NA NA
Sense Type NA
LF Window Up Blue
LF Window Down White
RF Window Up Brown/White
RF Window Down Purple/White
LR Window Up Dark Blue/White
LR Window Down Red/Black
RR Window Up Gray/Black
RR Window Down Green/White
Window Location At Driver's Window Switch
Windows Type Reverse Polarity, Positive, Normally Grounded
Notes Door Unlock may require relay; For keyless entry upgrade to an alarm, Arm = Blue, Disarm = Blue/Red, located in overhead console.
NOT INTEGRA
JEEP CHEROKEE (as per request)
jellofart
Audio / Security / Video
Mar 6, 2011 11:10 AM
95 LS
Jan 30, 2004 09:50 PM
integra-modder
10
Sep 29, 2002 07:03 AM
DocYahoo
15
Jul 20, 2002 04:29 PM
TurBoXBirD16
Feb 26, 2002 03:12 AM
