z6 vtec head on 90 civic dx
Old Feb 4, 2005 | 07:56 AM
92CivicLS's Avatar
Default z6 vtec head on 90 civic dx
well i wasnt able to get the Si dizzy, so i just didnt convert to mpfi, but i did do the swap, now after the head swap. speed sensor not working, no problem, the dizzy didnt fit on head by an inch, being not tall enough, so i zip tide it, w/e it works for now, no leaks no nothing.
so guys i ws wondering since i didnt get the SI dizzy, and it might not for on the vtec head, i have the dizzy that it came with, the OBD1 dizzy, to convert the dpfi to mpfi, i need that dizzy, because it has the CPS sensor in it, can i put the dx dizzy plugs on it, and the two extra wires leave them for the conversion will it work if i match the wires and convert it to OBD0 or is it going to have the firing order diffrent. PLEASE if someone out there understands me please help, i need to convert to mpfi, ASAP. please can the dizzy be converted to OBD0.
Thanx! email me if anything > lowcopr19@yahoo.com <
car runs but not enough fuel it pings like hell.
Old Feb 4, 2005 | 08:06 AM
dr_latino999's Avatar
Default Re: z6 vtec head on 90 civic dx (92CivicLS)
So let me see if have my premises straight
1) The car is still DPFI
2) The head is off a D16Z6
3) You are using an A6 Distributor
Correct?
Old Feb 4, 2005 | 08:08 AM
turboLSef's Avatar
In order to run an obd1 dizzy you need to wire to obd1 and use the ecu (p28) for it... or you can get a Si dizzy and just do the mpfi wiring with some kind of vtec/rpm activator...
Old Feb 4, 2005 | 08:11 AM
Default Re: z6 vtec head on 90 civic dx (turboLSef)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboLSef &raquo;</TD></TR><TR><TD CLASS="quote">In order to run an obd1 dizzy you need to wire to obd1 and use the ecu (p28) for it... or you can get a Si dizzy and just do the mpfi wiring with some kind of vtec/rpm activator... </TD></TR></TABLE>
But in going the OBD-0 route using a VTEC switch will enable VTEC but you will not have the adequate fuel maps to support it.
Old Feb 4, 2005 | 08:25 AM
turboLSef's Avatar
Default Re: z6 vtec head on 90 civic dx (dr_latino999)
there are some people who are putting vtec activation and the fuel maps for it onto pm6's so you can stay obd0... I cant find the link right now but I know its possible or use a vafc
Modified by turboLSef at 9:38 AM 2/4/2005
Old Feb 4, 2005 | 09:59 AM
CRseXy's Avatar
blah, after all that stuff, an obd1 conversion would be cheeper. IMO. z6 head, can only use a z6 Dizzy.
Old Feb 8, 2005 | 09:32 PM
92CivicLS's Avatar
Default Re: z6 vtec head on 90 civic dx (pogiTSI)
well guys im trying to use the p28 dizzy, and today i got the plugs changed to obd0 someguy up in westpalm told me it will work he's done it before. so i got the plugs changed and well lets see if it works, i will be doing as we speak, im trying to go to the track tomorrow. so lets see.....
Thanx for the help.
oh and im gonna use an LS ECU with SAFC2, and MSD RPM activated switch. 5,000 RPM pill. 5000 rpm for vtec and redline at 7,200 or 7,300 w/e it is.
trevorjohn88ef
Feb 10, 2008 12:13 AM
Sleeper91
Oct 11, 2007 06:33 PM
egturbo
Nov 3, 2004 02:43 PM
Vaans
Aug 31, 2004 05:34 AM
egizzle8
Feb 9, 2004 07:25 AM
