clutch won't work
Old Jan 15, 2002 | 02:37 PM
SOLORIO's Avatar
Default clutch won't work
hows it going guys and gals. well i got a problem. i have a 94 civic ex and my clutch is not letting me switch gears. i looked to see if i was out of clutch fluid and sure enough... i was. SO.. i put some in and it still doesn't let me shift. i also am scared to force it in because it feels like the stick will break. got any answers. do i have a leak?? i looked for leaks under the hood but nothng. i can't look under the car because it is snowing here. i just recently moved from california to utah, does the weather have anything to do with it?? i just installed shifter bushings, is that the problem?? please help.. thanks to EVERYONE that helps out
jesse
p.s. if you need more info i will give you more
Old Jan 15, 2002 | 04:39 PM
f0de's Avatar
Default Re: clutch won't work (trunks)
is the clutch pedal really limp? if so check your slave cylinder, that happaned to me.. or even the master cylinder.. other then that.. mebbe you ed the clutch up or the flywheel some way.. you can still drive the .. just start it in 1st gear.. give it gas.. and shift at the right rpm.. and downshift by reving the motor to meet the lower gear.. heh
Old Jan 16, 2002 | 02:46 PM
SOLORIO's Avatar
thanks i'll try that and check everything else. thanks again.
jesse
Old Jan 16, 2002 | 02:50 PM
Krow's Avatar
Why did you move from cali to utah?
Old Jan 16, 2002 | 05:43 PM
EVIL Hx Coupe's Avatar
Default Re: clutch won't work (Krow)
I love driving without clutch, not racing though. Check master cylinder, that went out on me once an dthe same thing happened.
94gsrdb8
Dec 9, 2008 07:48 PM
hatchsi0485
Nov 21, 2005 06:13 AM
herde1724
Oct 20, 2005 01:02 AM
ludelvr
Sep 12, 2003 04:20 AM
