JDM Honda Prelude Type S 220HP Piston
Old Feb 4, 2005 | 06:37 AM
Ice_man's Avatar
Default JDM Honda Prelude Type S 220HP Piston
Hi, this is the deal. I planing to build all motor h23 vtec. I almost have all the parts for it, but I have the problem deciding with which pistons I should go with. First should I go with JDM Honda Prelude Type S 220HP Piston Set 11.1 that are over sized by .25 or JDM Honda Prelude Type S 220HP Piston Set 11.1 that are not
oversize. The problem is if I would get the over sized ones do I need to reslive the block, becouse I still plan to do a preformance bore. I don't know if it would be better to go with after market pistons such as wiseko or JE. Any help or feed back or oppinion would be greatly appreciated.
Old Feb 4, 2005 | 08:40 AM
satan_srv's Avatar
Default Re: JDM Honda Prelude Type S 220HP Piston (Ice_man)
type-s pistons are made for the H22a, oversize ones are .25 which is within the re-bore limit for the FRM sleeve. Honda would not make an OEM piston that would require a re-sleeve.
and it's an 11:1 piston...not necesaryily 217hp. And with an H23 Crank the CR will be higher than that. And you'll need h23 rods bushed for floating wrist pins. And H23 cranks suck.
crownsk8er
Mar 11, 2009 08:22 PM
pentaq
Mar 3, 2009 12:33 PM
Bserieskiller
Nov 5, 2006 03:23 PM
gosu08
Aug 24, 2006 09:43 AM
honda head
Apr 17, 2006 08:59 AM
