will GSR spark plugs work in my h22?
Old Feb 4, 2005 | 12:49 AM
enigma94's Avatar
Default will GSR spark plugs work in my h22?
will some gsr spark plugs work in my h22 if gapped right?
this is a late night quick fix till i can get to a shop in the morning...
Old Feb 4, 2005 | 12:58 AM
@ries's Avatar
Default Re: will GSR spark plugs work in my h22? (enigma94)
what kind are they? ngk? what's the part #? they should work as long as they're the right ones for your gsr motor.
Modified by @ries at 2:12 AM 2/4/2005
Old Feb 4, 2005 | 01:17 AM
enigma94's Avatar
Default Re: will GSR spark plugs work in my h22? (@ries)
they are NGKs for a GSR and i put them in my H22. seems to work ok when regapped.....
but my **** is still fucked up so i dunno....
Old Feb 5, 2005 | 01:36 PM
Gerhard_001's Avatar
The B18C1/5, H22A use the same spark plugs, same heat range, same gap.
Old Feb 5, 2005 | 03:18 PM
v4lu3s's Avatar
RTFM
b18c1 BKR6E-11
b18c5 BKR7E-11
h22a4 ZFR6F-11
h22a1 ZFR6F-11
they will work but if they are gsr plugs id change them pretty soon to be safe since they are a bit hot to run all the time.
Old Feb 6, 2005 | 12:35 PM
cpforyou's Avatar
Default Re: (v4lu3s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s &raquo;</TD></TR><TR><TD CLASS="quote">
b18c1 BKR6E-11
b18c5 BKR7E-11
h22a4 ZFR6F-11
h22a1 ZFR6F-11
they will work but if they are gsr plugs id change them pretty soon to be safe since they are a bit hot to run all the time.</TD></TR></TABLE>
Both the ZFR6F-11 and BKR6E-11 are 14mm, 3/4" reach, 5/8" hex, gasket seat, resistor, ISO length, V-power (v-grooved center electrode), .044"gap
The difference is that the BKR6E-11 has a projected tip, and the ZFR6F-11 has a projected extended tip.
BKR6E-11s work in an H22A just fine. They are also a little cheaper too. If you have a highly modified All-Motor H22A or are running boost, I would try out the BKR7E-11s.
PphamEK
Feb 25, 2011 07:41 AM
22boost
May 18, 2007 12:21 PM
Boosthead
Dec 11, 2006 04:56 PM
electron-eg
Feb 12, 2004 07:11 PM
