What type of tires do you use? GSR models.
Old Feb 3, 2005 | 10:30 PM
XyKo
Guest
Posts: n/a
Default What type of tires do you use? GSR models.
I'm in need of a new set of tires, and was going for the Bridgestone Potenza but don't know which one to get.
I might considering buying 2 set of tires, one for summer and one for winter. So my questions is, what do you guys use on the winter and summer?
1. Name of manufacture of tires.
2. What model.
3. Summer or Winter? If you have two sets of tires, please list them.
4. All seasonal tires?
Looking for mostly stock rims, the blades. But any will do.
Modified by XyKo at 9:34 PM 2/4/2005
Old Feb 4, 2005 | 01:59 AM
Outkast95LS's Avatar
Default Re: What type of tires do you use? GSR models. (XyKo)
Yokahama AVS ES100.
I use it all year round. It doesn't snow in the bay area, so its sufficient enough. If it snows where you live, then get a set of snow tires to run for the winter.
Another good all season performance tire is the Falken Ziex 512
Old Feb 4, 2005 | 03:35 AM
delawaresfinest's Avatar
i just got kuhmo ecsta asx all weather performance tires. it snows where i am so i needed and all year tire. they seem to grip good on dry and wet roads
Old Feb 4, 2005 | 03:47 AM
XyKo
Guest
Posts: n/a
Default Re: What type of tires do you use? GSR models. (delawaresfinest)
Well, I'm from Boston, MA, so I think the weather is similar to yours.
Old Feb 4, 2005 | 04:47 AM
da'ee's Avatar
I use Bridgestone Potenza S-03 Pole Position, summer tire on my GSR(with blades) on the stock rims. The tire size is 195/50/15.
Modified by answer3 at 8:07 AM 2/4/2005
Old Feb 4, 2005 | 04:53 AM
furious94ls's Avatar
Default Re: What type of tires do you use? GSR models. (answer3)
Toyo T1S 195/55/15 on 15x6.5 Rota Slipstreams. Summer tire, excellent wet and dry.
Winter it sits on generic all seasons on steelies.
Old Feb 4, 2005 | 05:26 AM
Silver2000GS-R's Avatar
I was using Yokohama Avid T4's last summer....I hated them....then again, I don't think I like any all-season tire. I'm getting summer performance tires this year
Old Feb 4, 2005 | 05:31 AM
BDBGoalie1982's Avatar
Default Re: (Silver2000GS-R)
OBD II GSR Blades with 205/50/15 Falken Aziens
Summer tire, they aren't big fans of water or snow, but on dry pavement, there the best thing besides an R Comp
Old Feb 4, 2005 | 07:11 AM
da'ee's Avatar
Which Potenza tire were you looking at? Im assuming its either the S-03 or RE 010. I would go with the S-03 because they last longer and have better wet traction. I went with the 195/50/15 and I noticied acceleration increased due to the smaller tire. It gives razon sharp handling and are only $85/tire on tirerack.com. You can also go with the 205/50/15 S-03 but it would cost you a lot more.
Old Feb 4, 2005 | 07:18 AM
vain's Avatar
Default Re: What type of tires do you use? GSR models. (Nine5IntegraLS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nine5IntegraLS &raquo;</TD></TR><TR><TD CLASS="quote">Yokahama AVS ES100.
I use it all year round. It doesn't snow in the bay area, so its sufficient enough. If it snows where you live, then get a set of snow tires to run for the winter.</TD></TR></TABLE>
Old Feb 4, 2005 | 07:21 AM
The-LS's Avatar
Default Re: (BDBGoalie1982)
205/50/15 Falken Azenis
Old Feb 4, 2005 | 09:06 AM
n0 iNTegRiTY's Avatar
Toyo Proxes Z24 (all season)
205's
Old Feb 4, 2005 | 09:17 AM
JB20VTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BDBGoalie1982 &raquo;</TD></TR><TR><TD CLASS="quote">OBD II GSR Blades with 205/50/15 Falken Aziens
Old Feb 4, 2005 | 09:35 AM
iH8RICERZ's Avatar
Default Re: (JB20VTEC)
Yokohama AVS ES100's 205/45/16
More of a dry weather tire, but still doesnt do too bad in the rain. I've driven on worst. As for snow, definately not going to even try with these tires. I'd just pick up a set of steelies, and throw some cheapo snow tires if your worried about driving around in those types of conditions
Old Feb 4, 2005 | 10:31 AM
SMZ GSR's Avatar
Default Re: (iH8RICERZ)
Another tire that is almost identical to the AVS ES100 is the Sumitomo HRTZ-II (except that the Sumitomo is considerable less expensive)
I use those in 205/45/16 on my GSR and they work great. In wet or dry conditions they do well. Obviously better traction in wet can be had from tires like the S-03 but for the price of the sumitomo, you can't go wrong.
Old Feb 4, 2005 | 10:41 AM
vain's Avatar
Default Re: (SMZ GSR)
ES100s aren't that expensive to begin with
Old Feb 4, 2005 | 10:42 AM
SMZ GSR's Avatar
Default Re: (vain)
^ Very true. But saving 30-40 bucks on a set works for me
Old Feb 4, 2005 | 12:13 PM
teknoracing's Avatar
Default Re: (Black-LS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black-LS &raquo;</TD></TR><TR><TD CLASS="quote">205/50/15 Falken Azenis</TD></TR></TABLE>
Old Feb 4, 2005 | 01:34 PM
Moogen Powah's Avatar
Default Re: (JDMgangsta187)
Yokohama AVS ES100's also.
A very good overall tire for street use, with a low price.
Old Feb 4, 2005 | 02:36 PM
mkiv98's Avatar
haha jdmgangsta, which one?
Old Feb 4, 2005 | 02:49 PM
neo1z's Avatar
Another good all season performance tire is the Falken Ziex 512</TD></TR></TABLE>
Thats what I ran on my GSR. Excellent.
Old Feb 4, 2005 | 03:09 PM
GreenGSR's Avatar
Default Re: What type of tires do you use? GSR models. (neo1z)
I've been in the tire industry for a few years and have never seen an all season perform as well as a snow tire in the winter or as well as a wet/dry tire in the summer. The AVS ES100 is pretty popular, but for me it was noisy and only lasted for one summer. This is the first winter for my Ice Guards and i've been able to drive confidently thru conditions where 4WD's and AWD's just spun their tires. If you live where there's snow, and can afford both, it's definately the way to do it.
summer tire: 215/50/15 BFG G-force sport
winter tire: 195/55/15 Yoko Ice Guard
Old Feb 5, 2005 | 08:49 AM
XyKo
Guest
Posts: n/a
Default Re: What type of tires do you use? GSR models. (GreenGSR)
Anymore Northeastern Integra drivers? I know you guys uses winter or all seasonal tires right now.
Old Feb 5, 2005 | 09:15 AM
linda02916's Avatar
kuhmo ecsta
Old Feb 5, 2005 | 09:39 AM
aznballer's Avatar
yokohama es100 are a pretty decent summer tire size is 195 55 15
u will hear sum road noise tho
