93 ls with type r head ?'
Old Feb 3, 2005 | 10:13 PM
Honda97's Avatar
Default 93 ls with type r head ?'
hey i know search and search but i cant find anything. i got a 93 ls stock. want to swap a type r head. i want to know if anyone has this, has pics, and if you know everything that needs to be changed. Im gettin a type r head with 29k miles for $700. im wondering how much i would have to spend to make it a reliable swap. please help
Old Feb 3, 2005 | 11:06 PM
Slain's Avatar
take a gander over at the all motor forum. lots of info on lsvtec.
Old Feb 3, 2005 | 11:52 PM
sahtt's Avatar
Default Re: 93 ls with type r head ?' (Honda97)
Look around in the Sponser's section, they sell kits for your application for about 225.00 that include everything but the head. No modifications required except ofcourse tapping the oil pan.
Old Feb 7, 2005 | 09:49 PM
327da9's Avatar
Use the golden eagle kit with the oil filter adapter that comes with their kit, it makes life easy.
The only thing i would worry about would be deck warpage, since you dont plan on rebuilding the block. Plus with the stock bottom end and stock tranny, you wouldnt be able to take full advantage of type r head/cams and the overall better power band that comes with vtec.
If you want it to be reliable build it up right the first time, you should be able to get a b18a shortblock to buildup on the side for about $100-200. Get it machined, and go with shotpeened stock rods, and some higher compression pistons. Im to lazy to go over this whole thing so check the allmotor forum, its a good place to start.
It doesnt seem like it at first, but its cheaper to do it right the first time
Save your tax refund for a tranny too
Old Feb 7, 2005 | 09:58 PM
Sack Master's Avatar
Default Re: 93 ls with type r head ?' (327da9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sahtt &raquo;</TD></TR><TR><TD CLASS="quote">No modifications required except ofcourse tapping the oil pan.</TD></TR></TABLE>???
Old Feb 7, 2005 | 10:04 PM
crxnj's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda97 &raquo;</TD></TR><TR><TD CLASS="quote">im wondering how much i would have to spend to make it a reliable swap. </TD></TR></TABLE>
You cant just slap the head on the block and have it last..
Get this ****,,
GE lsvtec kit..(Lets you do it without machining the block..)
ARP rod bolts..(Stock b18a/b rod bolts stretch)
Balance the rotating assembly..(The ls block has a shitty stroke ratio and vibrates like a motha..And vibration will kill the oil pump gear and eventually kill the motor.)
Get a good ecu..Personally I would convert the head to obd1 and get a p72 ecu instead of converting your car to obd2 and getting a b18c5 ecu..
Old Feb 7, 2005 | 10:07 PM
crxnj's Avatar
Default Re: 93 ls with type r head ?' (sahtt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sahtt &raquo;</TD></TR><TR><TD CLASS="quote">Look around in the Sponser's section, they sell kits for your application for about 225.00 that include everything but the head. No modifications required except ofcourse tapping the oil pan.</TD></TR></TABLE>
You Dont tap the oil pan..You tap into the oil supply on the back of the block to get oil to the head..Use a t-fitting or the thing that comes in the lsvtec kit..
J_M_B
31
Jul 22, 2007 02:49 PM
Honda97
Feb 9, 2005 09:08 PM
Honda97
Feb 9, 2005 10:56 AM
4drBlankito2.0
Feb 13, 2004 12:05 AM
JSPECHB
May 28, 2003 11:55 AM
