WTB: D16 knock sensor
part number 30530-Pv1-A01
I need that and the plug that plugs into it
let me know what you have by pm'ing me; aiming me (honda of fury) or emailing me at computerjlt at yahoo.com
I'm using an obd2 99-00 si knock sensor on my obd2 D16 block. I'm sure any knock sensor will work as long as it's the same obd as your motor. This guy has an obd2 knock sensor just in case yours is too: https://honda-tech.com/zerothread?id=1093572
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chowmien »</TD></TR><TR><TD CLASS="quote">I'm using an obd2 99-00 si knock sensor on my obd2 D16 block. I'm sure any knock sensor will work as long as it's the same obd as your motor. This guy has an obd2 knock sensor just in case yours is too: https://honda-tech.com/zerothread?id=1093572</TD></TR></TABLE>
only the obd2 d's came with a knock sensor
I need a d16 knock sensor to use with my J&S Safeguard as its "tuned" for a d. I also need the plug for it cus my 90 si chassis doesn't have wiring for a knock sensor... or vtec... or a 4 wire o2... or.. well a lot of ****
no worries; i'l lhave about 40 wires popping thru the firewall
