Engine floods fuel pump won't stop running
Old Feb 3, 2005 | 06:46 PM
c_buz's Avatar
Default Engine floods fuel pump won't stop running
I disconnected both my vtec solenoid and my oil pressure switch and when I turn the ignition to the on position the fuel pump starts running and it won't stop priming. It then floods my engine completely, and fuel comes out of the intake. What could this be? Do the Vtec solenoid and oil pressure switch cause this? Would the car start if theese sensors are disconnected?
Old Feb 3, 2005 | 06:53 PM
c_buz's Avatar
Default Re: Engine floods fuel pump won't stop running (c_buz)
bump
Old Feb 3, 2005 | 07:08 PM
c_buz's Avatar
ttt
Old Feb 3, 2005 | 07:15 PM
CRX_Control's Avatar
im guessing your injectors are stuck open?
Old Feb 3, 2005 | 07:17 PM
c_buz's Avatar
Default Re: Engine floods fuel pump won't stop running (CRX_Control)
so what does that mean? How I fix it? Is it related to the vtec solenoid or the oil pressure switch being disconnected?
Old Feb 3, 2005 | 07:25 PM
you can hear your fuel pump prime and it wont stop priming as in the sound wont go away? it might just be that an injector is bad and needs replacing.
Old Feb 3, 2005 | 07:49 PM
c_buz's Avatar
exaclty. The fuel pump keeps running. This only started happening after I disconnected the ECT sensor and the Vtec solenoid. Could the ECT sensor be causing this?
Rus01
Oct 18, 2008 09:14 AM
ef8 h0!
Oct 3, 2005 05:32 PM
CRX_Control
22
Feb 22, 2005 07:08 PM
tiresmoke
Mar 23, 2004 11:25 AM
