building a b16
Old Feb 3, 2005 | 05:17 PM
EFMAN's Avatar
Default building a b16
ok so every body tells me that ctr piston and rods are the best . how does it affect the daily drivabilty , also how much power should this set up make and were can i find ctr rods or should i just keep my b16 rods ?
Old Feb 3, 2005 | 06:16 PM
_entropy's Avatar
Default Re: building a b16 (EFMAN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFMAN &raquo;</TD></TR><TR><TD CLASS="quote">ok so every body tells me that ctr piston and rods are the best . how does it affect the daily drivabilty , also how much power should this set up make and were can i find ctr rods or should i just keep my b16 rods ?</TD></TR></TABLE>
You can't run CTR rods in your B16 because CTR's use the taller B18 height block, instead of the shorter B16 block. CTR rods on a B16A will push the piston out of the cylinder at TDC.
GEN2 LS
Aug 15, 2009 07:51 AM
Pr0j3ctxH@tchx90
12
Jul 11, 2007 09:16 AM
dohcMONSTER
Jul 19, 2005 12:22 PM
evad
21
Dec 30, 2004 06:55 AM
