cam seals and dist seal ???
Old Feb 3, 2005 | 04:55 PM
eg6T's Avatar
Default cam seals and dist seal ???
should you replace cam seals and distributor seal like a gasket?meaning as if you take the head apart,then when putting back togther,replace the seals because they have already been in use?or will they be fine to reuse?thanks
Old Feb 3, 2005 | 05:35 PM
notstock93's Avatar
Default Re: cam seals and dist seal ??? (eg6T)
It's up to you, but you may as well replace them while you can. Unless they are already newer.
Doesn't really matter too much.
Old Feb 3, 2005 | 06:55 PM
eg6T's Avatar
Default Re: cam seals and dist seal ??? (notstock93)
thanks man
vlc92189
Mar 15, 2007 05:34 AM
eluder33
Apr 18, 2006 05:25 PM
Out of every "game"
Apr 16, 2006 02:41 PM
MattyP
Oct 14, 2004 03:59 PM
