For Those who have played with CATS...(Catalytic Convertor)
Old Feb 3, 2005 | 04:46 PM
EnjoyTheRideDC2's Avatar
Default For Those who have played with CATS...(Catalytic Convertor)
1994 Integra DB8 (4 door GSR)
Original OBD-1 Motor
Stock Exhaust
DC Headers
<U>The question is:</U> Will a Catalytic Convertor from a 1998 Integra Type R bolt right up into this car? Or, are there differences in length, width, and positioning of mounting holes?
Old Feb 3, 2005 | 04:48 PM
95lstegman's Avatar
Default Re: For Those who have played with CATS...(Catalytic Convertor) (EnjoyTheRideDC2)
i bet you $1 or more it will bolt right up. reason being is manifolds are a certain length and exhausts are a certain length, and you can mix and match as long as you don't mix a gs-r header/exhaust into the mix. so if those can be played with, the cat length must be constant. but why would you want an ITR cat? is it bigger? not likely.
Old Feb 3, 2005 | 05:03 PM
KOALA YUMMIES's Avatar
Default Re: For Those who have played with CATS...(Catalytic Convertor) (95lstegman)
Sure it might bolt up, but being an OBD1 car it doesnt have a 2nd 02 sensor, so the cat will have a hole about the size of a quarter when you put it on, and it will be loud.
Also they changed the exhausts slightly, some have the header B-pipe flange at a different angle and thus it might not bolt up.
I'll give you $1 if you dont assume dumb crap again.
Old Feb 3, 2005 | 05:43 PM
dFreezy's Avatar
Default Re: For Those who have played with CATS...(Catalytic Convertor) (KOALA YUMMIES)
it will not bolt up without modification because they are different lengths. 94-99 gsr's had shorter cats (~13") than all other integras (~17"), including type r's.
Old Feb 3, 2005 | 05:59 PM
Padawan's Avatar
Darth ModerVader
Default Re: For Those who have played with CATS...(Catalytic Convertor) (dFreezy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dFreezy &raquo;</TD></TR><TR><TD CLASS="quote">it will not bolt up without modification because they are different lengths. 94-99 gsr's had shorter cats (~13") than all other integras (~17"), including type r's.</TD></TR></TABLE>
This is mentioned occasionally, but I haven't seen any evidence of it, and it doesn't logically make sense. The '94-'99 GS-R has a B-pipe that is roughly 4" longer than other Integras. However, it also has an exhaust manifold (A-pipe) that is roughly 4" shorter than other Integras. Because of this, the cat lengths for all Integras, including the '94-'99 GS-R should be the same -- approximately 17.5".
Old Feb 3, 2005 | 06:41 PM
95lstegman's Avatar
Default Re: For Those who have played with CATS...(Catalytic Convertor) (Padawan)
exactly. thanks, oh great one.
Old Feb 4, 2005 | 08:03 AM
dFreezy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">This is mentioned occasionally, but I haven't seen any evidence of it, and it doesn't logically make sense. The '94-'99 GS-R has a B-pipe that is roughly 4" longer than other Integras. However, it also has an exhaust manifold (A-pipe) that is roughly 4" shorter than other Integras. Because of this, the cat lengths for all Integras, including the '94-'99 GS-R should be the same -- approximately 17.5". </TD></TR></TABLE>hmm...it was my understanding that the difference in a-pipe lengths was only an inch or two. i thought i remember read in numerous threads people stating their 94-99 gsr cats are only 13" long, the same length as the jdm itr cat. you are correct though.
RetroGamer
Jul 31, 2011 01:01 AM
JuggerNuts
May 31, 2006 12:25 AM
jdm91CrxSi
Oct 7, 2005 11:30 AM
intekragsr
Apr 12, 2005 12:22 PM
rough_draft
Apr 27, 2004 10:46 PM
