Clutch problem (inner wear) any else have this problem??
Old Feb 3, 2005 | 03:20 PM
incredteg3's Avatar
Default Clutch problem (inner wear) any else have this problem??
i had a built ls turbo that had about 300hp. before i fed it up. It had an 11lb aluminum flywheel. After tearing it apart i noticed a ton of wear on the inner portion of the organic disk and hot spots on the flywheel (inner as well). According to my machine shop aluminum flywheels flex which could have caused this. I am planing on replaceing my disk to a 6 puc sprung disk (the old one is garbage) but i don't what the same thing to happen again. the clutch spun once at the track when i tried to do a 2nd gear burn out. any one with info thank you i need to know weather or not to put this flywheel back on or not.
Old Feb 4, 2005 | 08:05 AM
incredteg3's Avatar
Default Re: Clutch problem (inner wear) any else have this problem?? (incredteg3)
bump
Old Feb 8, 2005 | 12:15 AM
incredteg3's Avatar
Default Re: Clutch problem (incredteg3)
no one??
Old Feb 8, 2005 | 06:25 PM
ssc_thomas's Avatar
I'd go with a better clutch first, the flywheel proply isn't your problem, but make sure the face of that flywheel is ture.
If it's worped it will be a problem even with a stronger clutch.
Old Feb 11, 2005 | 07:47 AM
incredteg3's Avatar
Default Re: (ssc_thomas)
if i have it resurfaced great but do they flex or what? i am getting a 6 puc and as of now i am sticking with the pp i have
Old Feb 11, 2005 | 11:15 AM
DSRxCandyh2bEG's Avatar
Default Re: (incredteg3)
try to use a solid disc instead of a sprung hub. Not much difference in driving but sprung hubs tend to pop easy, especially if your making 300 hp...
Old Feb 11, 2005 | 06:24 PM
ssc_thomas's Avatar
Default Re: (AVRh22EG)
what he said
also aluminum flywheels do flex in some apps but 300hp shouldn't be one of them
bank2me
Jun 5, 2011 02:13 PM
Mr.Luder
Jul 11, 2007 12:01 AM
gsf4726
Jan 15, 2004 10:00 AM
