Header swap then very bad fuel economy for a 98 civic
Old Feb 3, 2005 | 02:23 PM
Red Andy's Avatar
Default Header swap then very bad fuel economy for a 98 civic
My manifold was cracked so I priced it and it was about 900$ canadian. So I figured that I would bye headers and a cadalic converter seperate to save some money. By doing this, I had to extend my secondary O2 sensor wires about 3 feet. Now my engine light ls going on. The OBG2 says that it's my secondary oxigen sensor. So I replaced it. Still comes on so I changed the primary oxigen sensor and it still goes on. I have a new air filter, rotor and cap, never touched the timing and don't know what else to do.
I have a 98 Civic EX (LX for the US) and the manifold and cadalic is in one piece.
Highly appreciate some help!!
Old Feb 3, 2005 | 03:47 PM
yaya's Avatar
Default Re: Header swap then very bad fuel economy for a 98 civic (Red Andy)
what header did you buy? i have used aftermarket headers and they never req. me to extend any o2 wires. what did you use when you extended them? butt connectors? solder?
Old Feb 3, 2005 | 04:00 PM
drdisco69's Avatar
Default Re: Header swap then very bad fuel economy for a 98 civic (yaya)
Check your wiring for the sensor if the code comes on right away. If it comes on after driving a while, then the computer is sensing that the O2 isn't in the right place and that something is wrong.
Sucks about those one piece cat+manifold, huh. They all crack, don't feel bad. I don't know about in Canada, but in the US there's a 90k mile warranty on emissions components. What do you have up there?
Old Feb 3, 2005 | 04:16 PM
Red Andy's Avatar
I bought the headers on E-bay and I'm not sure what kind they are. The headers is a 4-2-1 style then i have to add cadalic afterwards. I soldered the wires, used shrink tube to seal it and taped it afterwards. [IMG][/IMG]
Old Feb 3, 2005 | 04:26 PM
Red Andy's Avatar
Default Re: Header swap then very bad fuel economy for a 98 civic (drdisco69)
Because it's a defect, they extended the warranty for 160 000 km's (about 90 000 miles). When I reset the light, it takes a little while for it to come back on.
I put on the headers myself with a buddy of mine and the mistake I did is I did not disconnect the battery. When I extended the wires, they touched it sparked a little bit. I hope that didn't hurt the computer.
A mechanic at Honda told me about a o2 simulator. Would that help?
Red Andy
Old Feb 4, 2005 | 09:17 PM
Smith Wise's Avatar
"Sometimes extending the wiring with tarnish the sensors ability to accurate transmit info." - This is what I was told by a reliable tech. If I were you, I'd plug in an o2 simulator into the harness and leave the other sensor in the bung to prevent a vaccum leak. this is what I did after all attempts to rid my 99 dx of a code 41 were unsuccessful.
good luck
Twest77
Oct 25, 2012 12:22 PM
BLU BY U
Sep 7, 2006 05:15 PM
Red Andy
Feb 7, 2005 02:13 AM
robbieshonda
Mar 2, 2003 10:06 AM
