NEED HELP ASAP
Old Feb 3, 2005 | 12:41 PM
SpoonREVS's Avatar
Default NEED HELP ASAP
i just bought a 95 GSR and while i was driving my ABS light came on. The brakes feels good no problems at all the fluid level is normal what can this be?
but here is what i really need where can i find the OBD 1 connector so i can plug in my scanner? i couldnt find it today
Also i want to install some killing switches does any one know where i can hook them up and how?
Old Feb 3, 2005 | 02:27 PM
marsbike's Avatar
From: Salt Lake City, Chicago at heart, UT or IL, USA
Default Re: NEED HELP ASAP (SpoonREVS)
you might just be a little low on brake fluid, but that might be something to check out. Use a paperclip, and you'll be able to pull the code. As for the link for the kill switch....https://honda-tech.com/zerothread?id=384077&page=1.
Old Feb 3, 2005 | 02:45 PM
SpoonREVS's Avatar
Default Re: NEED HELP ASAP (marsbike)
Thanxs but what you mean with a paper clip
Old Feb 3, 2005 | 03:22 PM
marsbike's Avatar
under the glove box, there is a little green thingey. Pull the plug out of it, take a paperclip, bend it around so it fits and jumps the connection, put it in, turn the key to the ACC position, then watch your CEL light, and it'll give you the code.
Old Feb 3, 2005 | 03:34 PM
SpoonREVS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by marsbike &raquo;</TD></TR><TR><TD CLASS="quote">under the glove box, there is a little green thingey. Pull the plug out of it, take a paperclip, bend it around so it fits and jumps the connection, put it in, turn the key to the ACC position, then watch your CEL light, and it'll give you the code.</TD></TR></TABLE>
oh ok cool. jsut need one? i notice that theres a small one and a larger plug do i connet the clip to the larger one to the small one? or just in one of the plugs? Also does it matter in which color wired i placed the clip in?
Old Feb 3, 2005 | 03:37 PM
Mordeki's Avatar
Abusing my rights one day at a time.
learn something new everyday
jlfrnce
May 13, 2007 02:40 PM
mousiex113
Jun 29, 2006 06:00 PM
SpoonREVS
Feb 9, 2005 02:55 PM
shettysaab
May 18, 2004 12:38 PM
