Cross drilled rotors owners..
Old Jan 15, 2002 | 11:27 AM
IntegraGSR23's Avatar
Default Cross drilled rotors owners..
I've done a search and no luck.
People with cross drilled rotors, when it comes time to do brakes, how does one go about getting them re-surfaced? Or is this not necessary? Reason, I am asking is because a friend has some and is converting car back to stock and offered them to me.
Thanks in advance
Old Jan 15, 2002 | 11:36 AM
Black96Cobra's Avatar
Default Re: Cross drilled rotors owners.. (IntegraGSR23)
Cross drilled rotors are not resurfacable. I wouldn't take them, they are just pimpy but have no real advantage.
Old Jan 15, 2002 | 11:42 AM
Default Re: Cross drilled rotors owners.. (Black96Cobra)
Thats what I thought but wasn't sure of that. Thanks! Anyone else??
[Modified by IntegraGSR23, 12:42 PM 1/15/2002]
Old Jan 15, 2002 | 12:15 PM
9GRedline's Avatar
I don't think they can be resurfaced either, but not 100% sure. I also heard that cross-drilled rotors warp or bend after time. Just get some OEM brembos. If you look around you can get them for a decent price. Good luck.
Old Jan 15, 2002 | 12:55 PM
Chris's Avatar
Default Re: Cross drilled rotors owners.. (9GRedline)
driled will crack. they are considered "show" rotors. Yes Porsche uses them, and they crack there all the time also.
Oh and I think they ARE NOT resurfaceable.
Old Jan 15, 2002 | 02:10 PM
Chris's Avatar
Default Re: Cross drilled rotors owners.. (Chris)
SEE! This is a Porsche...
Old Jan 15, 2002 | 02:33 PM
Yikes! That doesn't look nice. After seeing these replies, especially the pic I may not take them from him. You all have been a great help! I appreciate it Keep them coming
Old Jan 15, 2002 | 06:19 PM
vhd's Avatar
vhd
they can be machine/resuface within its limits just like any rotor as long as they are not cracked, etc., look on the rotor for the spec(s) and have the it mic'ed to see if its still resufaceable
Old Jan 15, 2002 | 07:22 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Cross drilled rotors owners.. (vhd)
How? Don't the cross-drill hole edges catch the bit or whatever it is that actually removes material from the rotor surface? I've also heard slotted is better for a daily driven car if you want increased performance, but I don't know if those can be resurfaced, either. If you get slotted rotors, make sure the slots stop before the edge of the rotor. It will be stronger than a rotor w/ slots that go all the way to the edge.
Old Jan 15, 2002 | 07:56 PM
akhom's Avatar
Default Re: Cross drilled rotors owners.. (Teken)
Well said Teken..
Old Jan 16, 2002 | 04:45 PM
milano's Avatar
Default Re: Cross drilled rotors owners.. (akhom)
it can be resurfaced and machined
i just got mine done at my mechanic's shop
i have the Power Stop cross drilled rotors
well said teken!!
[Modified by milano, 1:47 AM 1/17/2002]
Motionek55
10
Sep 8, 2012 02:04 PM
JHD_DA
Aug 12, 2004 06:40 AM
ek44
Apr 25, 2004 08:04 PM
tmekjian
May 10, 2003 04:04 PM
hb_racer
Apr 14, 2002 08:55 AM
