Bad Clutch?
Old Feb 3, 2005 | 08:25 AM
Senbonzakura's Avatar
Default Bad Clutch?
Okay, i know this is a Honda/Acura website. But i've been here for a while ever since I got my integra. As of now I got a 95 240SX and its pretty hard for me to put it into first and reverse. Hell I can't even put it into first. What could it be?
Its really really hard to put it into first and also when I put it into reverse, the car just moves back by itself without mixing the gas. It just moves backwards when its in reverse. Also when I revved it when it was in neutral the check engine light comes on then it disappears when it goes back to idle. Help is appreciated, thanks again Honda-Tech.
Old Feb 3, 2005 | 09:39 AM
tegmech's Avatar
do you let out the clutch when its in reverse? or does it go with the clutch pushed all the way in? Probably a bent clutch fork though.
Old Feb 3, 2005 | 09:59 AM
Default Re: (tegmech)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegmech &raquo;</TD></TR><TR><TD CLASS="quote">do you let out the clutch when its in reverse? or does it go with the clutch pushed all the way in? Probably a bent clutch fork though.</TD></TR></TABLE>
The clutch is all the way in and the car just backs up.
Old Feb 3, 2005 | 12:03 PM
Honda Hick's Avatar
Default Re: Bad Clutch? (Kyo Kusanagi)
Hmm, it may be your master or slave cylinder. They may not be holding your clutch as you have the pedal down. I'm not too sure on the check engine light though. Is there anyway to check the ECU codes?
I would do the slave cylinder either way. It's cheap, like $20, and they tend to go on 240's. My buddy and I have had to replace many of them on his cars and other SR20 swap cars we've done.
BTW, you might have better luck (if it's not the slave or master cyl) on http://www.nicoclub.com/
That's a good forum for Nissan stuff.
Old Feb 3, 2005 | 09:28 PM
Default Re: Bad Clutch? (Honda Hick)
Thanks a lot
Old Feb 4, 2005 | 01:49 AM
teknoracing's Avatar
Im gonna go with bent clutch fork. I had it break on my sentra, not fun, lucky for me it was right off the exit by my house so i strolled it in 2nd.
Its not a fun job because if its anything like my SR20, you have to remove the bell housing to replace it.
Old Feb 4, 2005 | 11:09 AM
Default Re: (teknoracing)
Actually, I don't know what happen. I let my friend drove it and when it came back, everything went back into place. I'm still going to get it replace but its just weird.
The gears goes in fine now and what not. The only problem I'm having right now is that the check engine light keeps blinking on and off. I'm going with a bad sensor.
globy123
Nov 29, 2007 11:21 AM
Cypher0117
23
May 16, 2005 07:15 PM
.water
Oct 16, 2004 05:24 PM
akteamster
Aug 18, 2004 01:18 AM
hondaracin24
Aug 5, 2004 02:26 AM
