combination switch prob very weird....
welll my corner lights stay on even when the switch is on off
what could be the problem i evne unplugged the hrness formthe switch and it still stays on
any help would be appericated
tnx in advanceed
any help would be appericatedtnx in advanceed
I'm looking now for the 81 accord schematic, I'll get back to ya when I can find it.
Then I'll get the crystal ball out to find out what else has been done or checked on the car. Thanks for all the info you've been a great help to yourself
Honda uses 'switch to ground' system so the lights wiring being grounded any where before the switch could cause the problem. Do you have a security system maybe? or you could have the light switch off/ unplug a light and do a continuity check to ground.....then follow the schematic"point to point" to find what is grounding the circuit.
You can grab the schematics here .... PDF files
http://members.troublecodes.ne...4.pdf
http://members.troublecodes.ne...5.pdf
The 97 schematic should be very close to your cars
89_honda_accord
Jan 26, 2005 11:43 AM
