DOHC ZC ??'s!
Sup fellas...I've been looking and I've read many things.....and I need to figure it out asap......
I have a DOHC ZC in my 92 hatch....obd1 etc etc....well its maintance time and I Need to change out some gaskets and do a lil up grades...
WHat intake manifold gasket do I use?? 89 teg which is d16a9?
What TB gasket do I use?? 91 crx si which is d16a1? or is it a6?
Has anyone bolted on a diff OEM TB to the ZC intake mani?? h22 maybe??
I also need the intake manifold studs and the valve cover studs?? has anyone replaced these before?? could I get them at a hardware store maybe and not have to go through the dealer??
sup man. this is the page i sue for all my info http://dmoore.com/crx/zc.htm
hmm yeah part numbers are good, but the dealer I call or go to knows jack **** what motor cam in what car...
So I kinda need to know what car/motor the part # correspond too, not just the car...
d16a8/9 are 88-89 teggy right?
what are the:
d16a1
d16a6??
what are the:
d16a1
d16a6??
d16a1 is US, d16a8/9 are UKDM Honda/Rover. HTH.
The TB gasket will be 88-91 civic/crx si (d16a6), the IM gasket will most likely be d16a1 88-89 teg, I assume that the stud you need will come from a teg as well. I would ask this on d-series.org & thezcr.com.
Screw you guys, I'm... going... home.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SloCivicHMM »</TD></TR><TR><TD CLASS="quote">hmmm
but d16a8 and d16a9 are US motors?? from the 88-89 Teggy??
Anyone have info on what the d16a1 is??</TD></TR></TABLE>The D16A8/9 are EDM (euro) engines and your USDM parts guy might not have info on them. The D16A1 came in 86-89 USDM integras in two different flavors. The 86-87 models had vacuum advance ignition and the 88-89 models had electronic advance ignition. They also had slightly different rods and pistons. The two best places for info on these engines are http://www.thezcresource.com and http://www.g1teg.org . Beyond that I don't know much else about them but those two sites should.
hey man i've never been to this site before but check this out. I'm in germany and motorcodes are real pain in the *** here. the d16a1 was in the86-89' integra. they didn't have integras here yet. but the87' crx had the zc-1 1.6i dohc. i wonder if this is the same motor but with eu enginecodes?
any help anyone
mesean13@hotmail.com
any help anyone
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mesean13 »</TD></TR><TR><TD CLASS="quote">hey man i've never been to this site before but check this out. I'm in germany and motorcodes are real pain in the *** here. the d16a1 was in the86-89' integra. they didn't have integras here yet. but the87' crx had the zc-1 1.6i dohc. i wonder if this is the same motor but with eu enginecodes?
any help anyone
mesean13@hotmail.com</TD></TR></TABLE>
I'm pretty sure that it is very similar to the early JDM browntop ZCs and the 86-87 USDM browntop D16A1. Is it vacuum advance ignition or electronic advance ignition?
any help anyone
i'm pretty sure it's a vacuum advance. I'm trying to do a d16a1(zc1?) swap for my d15a3civic si hatch(german spec/motor is called EW4). problem is d16a1 is an integra(86-89')motorcode.They never made integras in germany till like 91', so I need to find out if the german spec. zc1 is the same as the d16a1.They had it in the 87'crx over here.
Mr.Death
Jun 22, 2006 12:18 PM
VelocityR
Nov 14, 2003 07:22 AM
LSturboHB
Jul 12, 2002 06:22 AM
