Front Camber Kits
Hey guys. I just installed my new suspension and camber kits but I had some trouble with the front ones. For the front I used SPC's and I couldn't get the two slide plates pressed into the upper control arm. Instead I just clamped all the pieces together and tightened the 22mm bolt. It seems to have worked even though my camber is off because now when I drive I hear a pop every time I turn. I'm not sure if its due to the camber or if the upper control arm is banging inside the wheel well. If anyone has encountered these problems and can provide some feedback I'd appreciate it. Thanks.
..::91TEG-G2::..
May 23, 2004 01:53 PM
eTec
19
May 21, 2002 04:51 AM
RineRacing
May 8, 2002 05:03 AM
