Resetting ECU
Old Feb 3, 2005 | 05:20 AM
st3alth's Avatar
Default Resetting ECU
Anyone know how to reset the ECU on a 95 dohc h22a prelude?
Thanks
Old Feb 3, 2005 | 05:30 AM
Yield's Avatar
uhh, disconnect the battery for a minute.
Or, pull the radio fuse.
Old Feb 3, 2005 | 05:51 AM
john d
Guest
Posts: n/a
Default Re: (Yield)
10whp mod
Old Feb 3, 2005 | 07:39 AM
JDMAflac's Avatar
i thought it was for 15 mins?
Old Feb 3, 2005 | 07:55 AM
Sticky Tires's Avatar
* B A N N E D *
Default Re: (AznLuder704)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AznLuder704 &raquo;</TD></TR><TR><TD CLASS="quote">i thought it was for 15 mins?</TD></TR></TABLE>
No way, 30 seconds is fine.
Aren't 95's obd1? I thought you only need to reset the ECU on obd2's?
*shrug*
Old Feb 3, 2005 | 08:19 AM
sharkcohen's Avatar
Default Re: (Sticky Tires)
Only use of reseting an ECU is to clear a trouble code.
Old Feb 3, 2005 | 08:40 AM
chrisgags13's Avatar
Default Re: (sharkcohen)
correct. and yea they are obd 1 but all computers set trouble codes which are usually clear by disconnecting the battery for like 30 secs. hope this helps
Old Feb 3, 2005 | 10:02 AM
* B A N N E D *
Default Re: (chrisgags13)
That's what I thought.
Old Feb 3, 2005 | 10:14 AM
SKDRCR's Avatar
Default Re: (john d)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by john d &raquo;</TD></TR><TR><TD CLASS="quote">10whp mod</TD></TR></TABLE>
You for got to add teh
Unless you're referring to reflashing an ecu out of a k20 or something
Old Feb 3, 2005 | 10:18 AM
dmxsoulja3's Avatar
Default Re: (SKDRCR)
Should you reset it only when the engine is warm? what if you had to have the battery unhooked for a few days..I plugged it all back up and now my car is running rich when I start it, puffing black smoke, a/f all the way on last green bar, I shut it off and haven't messed with it since..is this normal? what should I do.
Old Feb 3, 2005 | 10:20 AM
SKDRCR's Avatar
Default Re: (dmxsoulja3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dmxsoulja3 &raquo;</TD></TR><TR><TD CLASS="quote">Should you reset it only when the engine is warm? what if you had to have the battery unhooked for a few days..I plugged it all back up and now my car is running rich when I start it, puffing black smoke, a/f all the way on last green bar, I shut it off and haven't messed with it since..is this normal? what should I do.</TD></TR></TABLE>
It shouldn't matter wether the car is warm or not.
Are getting a CEL?
Old Feb 3, 2005 | 11:27 AM
sharkcohen's Avatar
Why did you reset the ECU in the first place? Was the car running properly, without CEL, before you reset the ECU?
Wait a second, you are this guy: https://honda-tech.com/zerothread?id=1137197
You may have other issues.
Old Feb 3, 2005 | 11:30 AM
dmxsoulja3's Avatar
I unhooked the battery because I was unhooking the ecu so I could get to the sunroof drain outlet in the floor panels...I put it all back together, fire it up, it smells like I'm dumping gas and its puffing black smoke pretty good, so I shut it off
Old Feb 3, 2005 | 11:34 AM
mgags7's Avatar
dude two discussions on the same thing
and did the creator of this thread know there was a search button conveniently located in the top right of each page
use it.....this is the most simple **** ever, and about the 1 millionth time i have seen a thread like this.....
Old Feb 3, 2005 | 11:36 AM
dmxsoulja3's Avatar
Default Re: (mgags7)
I wasn't trying to start two discussions, but based on the topic of discussion being ecu resetting I was wondering if I was doing it correctly based on the info everyone was giving this topic starter. my bad man, not trying to stir up anything
Old Feb 3, 2005 | 11:41 AM
sharkcohen's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dmxsoulja3 &raquo;</TD></TR><TR><TD CLASS="quote">I wasn't trying to start two discussions, but based on the topic of discussion being ecu resetting I was wondering if I was doing it correctly based on the info everyone was giving this topic starter. my bad man, not trying to stir up anything</TD></TR></TABLE>
You were wondering if you did what correctly? You had the ECU out of the car.
Old Feb 3, 2005 | 11:43 AM
dmxsoulja3's Avatar
well is it typical to put it back in, fire it up and it to puff black smoke as its relearning? thats what I'm guessing is not normal. I'm not throwing any CEL's so I'm kinda stuck trying to figure out a starting point. I appreciate the help guys you guys are great
Old Feb 3, 2005 | 11:44 AM
mgags7's Avatar
not normal, i put up a post on your other thread....
check it out
Old Feb 3, 2005 | 12:21 PM
4.6LJeepXJ's Avatar
Disconnecting the battery terminal doesnt hurt anything. As far as a re-learn...anytime you reset the ecu the learned memory you car has stored is dumped. Your car is running in a default mode until it re-learns your driving habits. Your car doesnt run of this memory at cold start up though. your car runs in open loop meaning that the computer is not talking to your O2 sensors (OBD2) and it cant tell what the air/fuel ratio is... at this point it relies on its PROM to run. the prom runs until about 600 degrees which is when your O2 sensors will become closed loop with the ecu. Hope this helps.... if its black smoke did it have trouble starting up you probably flooded it out.
Old Feb 3, 2005 | 12:27 PM
dmxsoulja3's Avatar
Default Re: (4.6LJeepXJ)
no it starts up just like it always does, idles like it always does, it just is puffing black smoke and smells like gas. I shut it down and didn't continue as I had to go to work.
uscivicmc
Nov 7, 2005 07:26 PM
Boring
10
Dec 3, 2004 11:31 AM
skeptic
Nov 10, 2004 09:16 PM
streetspeed607
May 11, 2004 07:18 PM
Fatty_1775
Aug 5, 2003 05:37 AM
