4th Gen JDM Foglights
I'm getting some JDM Foglights including the switch but how do I hook them up? Do I have to run them through the computer, or can I set them up on their own circuit? Any ideas would be greatly appreciated. What's the bext way to do it. I will also have incomplete wiring, just a few inches from the switch and each of the lights. THanks.
when you look in the bumper attached to the harness for the turn signals there is a plug that reaches and seams as though its for the addition of the stock foglights.. any idea if this it true and is the wiring fused with a plug available somewher the cabin to be attached to a switch?
i will see if my helms has anything on this at lunch
relay them through your cigarette lighter so they turn off when the car is off, wire the switch, poke the wires through the firewall and out to the fog lights. Make sure to put quick disconnect things (i think thats what they're called) by the fogs so that you can remove the bumper without having to cut the wires.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92LudeSI »</TD></TR><TR><TD CLASS="quote">Yea you can get them there. Under electrical components- exterior</TD></TR></TABLE>
112608 FOGLIGHT NO COLOR 335.39 251.54 Qty:
98354 LENS, FOGLIGHT NO COLOR 20.82 15.62 Qty:
112609 FOGLIGHT ASSY., FR. NO COLOR 164.57 123.43 Qty:
112610 BRACKET, R. FOGLIGHT NO COLOR 28.13 21.10 Qty:
112611 BRACKET, L. FOGLIGHT NO COLOR 28.13 21.10 Qty:
112612 GARNISH, R. FOGLIGHT NO COLOR 20.82 15.62 Qty:
112613 GARNISH, L. FOGLIGHT
What do i need?
What do i need?
as far as installing them, they should come with the wiring long enough to include the clips.....
wire from the back of those clips into whatever wire you want to run.....i put mine on the parking lights....
to use the switch you will either have to find wiring diagrams for the switch and custom do it, or you can buy the relay and subharness from the website, then it will all plug up.....
but if you do ^^ they will only come on if you have on the headlights, i like how mine look with just the fogs/parking lights on....but its up to preference....
TaboR
Nov 30, 2001 07:54 AM
