Need help! no spark, and no car, make jose, something, something...
Old Feb 2, 2005 | 10:52 PM
civicdust's Avatar
Default Need help! no spark, and no car, make jose, something, something...
Alright, im fixing a 90 acura integra, and its getting no spark.
Theres a wire on the fuse box that looks, ripped, and i wanna know what that one wire does.
its one of those that you pull. (fuse box in engine bay).
i will get wire color in awhile
any other reason why i wont get spark?
i searched, and didnt come up with much 411 on DA's
Old Feb 2, 2005 | 11:14 PM
civicdust's Avatar
Default Re: Need help! no spark, and no car, make jose, something, something... (robocop)
wire is white with green stripe
Old Feb 3, 2005 | 01:37 PM
civicdust's Avatar
Old Feb 3, 2005 | 02:37 PM
Thrillhouse's Avatar
go crazy?
check battery voltage, check dizzy, check continuity of plug wires, check plugs, does it turn over? does it get fuel? check fuses (you prolly did already) check ignition module, get a manual of some sort. good luck, last time i did a no start and it didnt get any fuel or spark it was the ecu.
Old Feb 3, 2005 | 02:58 PM
civicdust's Avatar
Default Re: Need help! no spark, and no car, make jose, something, something... (Thrillhouse)
i get fuel, its tried\s to turn over, but im getting no spark. Im guessing its that one wire i mentioned
Old Feb 3, 2005 | 03:42 PM
hatchinprogress's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Thrillhouse &raquo;</TD></TR><TR><TD CLASS="quote">go crazy?
</TD></TR></TABLE> dont mind if i do
Old Feb 7, 2005 | 08:41 PM
usfsfirefighter0's Avatar
Default Re: Need help! no spark, and no car, make jose, something, something... (1ej1)
Is the wireharness arcing on the motor at all there maybe short? If not the distributor it could also be the computer try put a your ecu in a friends car with similiar swap, u can try to putt another ecu in yur car, or u can also do this with distributor. Also check check ign fuse (15 amp) in the fuse box in the dash and the engine bay ? Hopefully this works or steers u to the problem but if u find the problem please let me know ok?
desiromeo812
Dec 18, 2008 05:35 PM
yoursupahero09
10
Jan 23, 2007 04:19 AM
CLE
11
Aug 1, 2006 08:23 PM
DeDonDeRosa
Dec 8, 2005 06:45 PM
Trinity
13
Sep 4, 2002 06:01 PM
