Defective oil rings?
Old Jan 15, 2002 | 10:47 AM
JSpecwest's Avatar
New User
Default Defective oil rings?
As some of you know, I recently took my motor to a local shop to for a rebuild. My motor was burning oil after I got it back so I had the head pulled and there are deep scratches in my # 4 cylinder. I spoke to the shop about it and the owner claims he sees defective oil rings all the time and if this was the case, he would not fix my problem for free. Ive spoken to other specialty shops that just work on hondas and they said they have never seen a defective set of rings from Honda. I was just seeing if anyone else had come across a defective oil ring set from Honda.
Old Jan 15, 2002 | 10:49 AM
Big Phat R's Avatar
Default Re: Defective oil rings? (JSpecwest)
He's pulling your chain. There was probably some residue/dust/metal filings/whoknowswhat left in the cylinder when the engine was rebuilt that caused the scratching.
Old Jan 15, 2002 | 10:54 AM
sgT's Avatar
sgT
They probably messed up with installing the piston and the oil rings got caught
between the piston and the wall. I've seen that happen before.
Old Jan 15, 2002 | 11:00 AM
Mike K's Avatar
Default Re: Defective oil rings? (sgT)
I bet it was one of the scraper rings.. the two real tiny ones that go on either side of the spacer.
I've seen this happen when a Craftsmans ring compressor is used.
I prefer the KD Tools band and pliers type.
Old Jan 15, 2002 | 11:31 AM
JSpecwest's Avatar
New User
Default Re: Defective oil rings? (Mike K)
So Mike you think it could have been defective?
Old Jan 15, 2002 | 01:05 PM
sgT's Avatar
sgT
No. Improper installation.
Old Jan 15, 2002 | 02:16 PM
non-VTEC's Avatar
i'll have to agree with that........the oil rings can be tricky to line up and seat properly on the oil ring land........
Old Jan 15, 2002 | 02:21 PM
sgT's Avatar
sgT
Default Re: Defective oil rings? (non-VTEC)
no. its not tricky. you just cant be careless when you install the piston.
Old Jan 15, 2002 | 02:29 PM
Warren's Avatar
Wrong-Way Wang
They probably messed up with installing the piston and the oil rings got caught between the piston and the wall. I've seen that happen before.
Yeah I wonder where...
Warren
Old Jan 15, 2002 | 04:43 PM
Mike K's Avatar
Default Re: Defective oil rings? (Warren)
Old Jan 15, 2002 | 05:34 PM
Warren's Avatar
Wrong-Way Wang
My car, before he rebuilt it :/
Warren
Old Jan 15, 2002 | 05:55 PM
JSIR's Avatar
New User
when you say problems burning oil, what quantity of oil being lost over what number of miles, or was your exhaust noticeably blue in colour ?.
J.
benjoh
Oct 30, 2017 02:08 PM
FireInTheHead
Nov 4, 2014 04:15 PM
joss731
Sep 15, 2010 08:50 AM
jtracing919
Jan 25, 2006 05:06 PM
