tire wear
Quick question for everyone. Do you notice your rear tires wearing out extremly fast ? Just want to know if it's normal. ( by fast i mean about 8000 miles) My current tire is the yokohama avs es 100 and i'm riding on tein Stech's
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hypnosisracing »</TD></TR><TR><TD CLASS="quote">im enjoying getting good mileage out of our stockers...</TD></TR></TABLE>
<----- 8,000 miles on stock tires on stock susp.
Of course, my driving habit had something to do with it
Damn dude...my wife drive's hers daily and our Potenza's are still like new, we've not put them through MUCH abuse but we have drive it hard a good bit of times...i dunno, we're getting closer and closer to 10K day by day, i see them lasting well past that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by revhi »</TD></TR><TR><TD CLASS="quote">I got almost 14000. Its becasue I rotated and remounted them. The steel belt things were coming through the rubber when I finally changed tires.</TD></TR></TABLE>
how can you rotate? ours are directional and staggered
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by revhi »</TD></TR><TR><TD CLASS="quote">yor remount on each back rim. most the wear is onl on the inside edge anyway.</TD></TR></TABLE>
so that means your tires are backwards
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by revhi »</TD></TR><TR><TD CLASS="quote">NO, Papa Smurf, swap left to right rears. Inside sidewall turned to outside side wall. Still in the correct direction.</TD></TR></TABLE>
i did not know that was doable
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by revhi »</TD></TR><TR><TD CLASS="quote">I got another few thousand miles this way.</TD></TR></TABLE>
our insides seem to wear the most. even worse with aggressive alignment
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nishant »</TD></TR><TR><TD CLASS="quote">our insides seem to wear the most. even worse with aggressive alignment</TD></TR></TABLE>
Right. Thats why when you rotate left to right, the inside turns to the out side edge.
Right. Thats why when you rotate left to right, the inside turns to the out side edge.</TD></TR></TABLE>
yeah i figured that out but doesn't that affect handling?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by revhi »</TD></TR><TR><TD CLASS="quote">Handling was fine. You have more tread to work with now.</TD></TR></TABLE>
i will have to try this next time, what mileage did you do this at?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CWESTINDC2 »</TD></TR><TR><TD CLASS="quote">i'm only getting 4,000 miles out of my falken rear tires.</TD></TR></TABLE>
falken azenis?
falken azenis?
