Disabling EGR Valve on 2.2 Liter
Old Feb 2, 2005 | 07:40 PM
dshook's Avatar
Default Disabling EGR Valve on 2.2 Liter
Would there be a problem if I were to unhook and plug the vacuum line going to the EGR Valve and drive it for a day??
Thanks,
Darrin
Old Feb 2, 2005 | 08:47 PM
FSTASNTZ's Avatar
Default Re: Disabling EGR Valve on 2.2 Liter (dshook)
I would think it would throw a CEL, not sure about any other side effects. Why do you want to unhook it for a day?
Jason
Old Feb 3, 2005 | 10:47 AM
Mike813's Avatar
Default Re: Disabling EGR Valve on 2.2 Liter (FSTASNTZ)
yep it would throw a cel when it gets activated... if you want to disable it, someone had a write on on blocking it through the ports, all you needs a small sheet of gasket + gasket sealant and you are set to go...
Old Feb 3, 2005 | 11:41 AM
Luisito825's Avatar
Default Re: Disabling EGR Valve on 2.2 Liter (Mike813)
nothing will be damaged. just CEL.
spray004
Jun 30, 2011 01:53 PM
LukieLuc
Feb 29, 2008 06:05 PM
shifts
Apr 5, 2007 11:51 AM
DarkBB4
Nov 8, 2004 05:08 PM
