B18C head oil leak
Old Feb 2, 2005 | 07:25 PM
AlxSiR7's Avatar
Default B18C head oil leak
i noticed a little bit of oil leaking out under the distributor area and right where the block says "B18C".. it's not enough to notice a difference when checking oil or anything, but I still don't want a leak. Think the head could have been torqued down incorrectly when the metal head gasket was put in?? What should it have been torqued down at & how can I fix this leak??
Old Feb 2, 2005 | 07:30 PM
AllMotorGSR94's Avatar
check the dizzy O- ring and the vtec unit seals.
Old Feb 2, 2005 | 07:39 PM
AlxSiR7's Avatar
Default Re: (AllMotorGSR94)
good idea.. thanks man
Old Feb 2, 2005 | 09:06 PM
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
Default Re: (AlxSiR7)
the passanger side, exhaust cam seal might need to be changed.. i would think oil would drip down on the engine code stamp from the front side of the engine, not the back by the distributor.
Old Feb 2, 2005 | 11:07 PM
tnord's Avatar
Default Re: (Built B16A)
get the distributor cap o-ring and and end-cap, i bought both from acura for like $12. isn't hard to do either.
without pictures i can't say for sure if that's the problem or not.
Old Feb 2, 2005 | 11:30 PM
Built B16A's Avatar
Default Re: (tnord)
its possible, but i find it hard to belive the distributor O ring is leaking all the way up front by the Engine ID stamp... i see either a VTEC sol. gasket, or exh. cam seal writen all over this one.
Old Feb 3, 2005 | 12:11 PM
AlxSiR7's Avatar
theres no oil near the vtec sol. so i know its not that gasket.. but it could very well be the exhaust cam seal... anyone want to tell me how to change this??
Old Feb 3, 2005 | 01:44 PM
Built B16A's Avatar
https://honda-tech.com/zerothread?id=1136114
all it took was a simple search.
Old Feb 3, 2005 | 01:50 PM
AlxSiR7's Avatar
thanks man so if it's not leaking around the vtec sol. then it should be the cam plug? #8??
Modified by AlxSiR7 at 6:24 PM 2/3/2005
Old Feb 3, 2005 | 02:33 PM
old_school_dohcvtec's Avatar
Default Re: B18C head oil leak (AlxSiR7)
hey man i got the same problems, i went to a mechanic today and he told me to get these parts at the dealer: distrubuter O ring, vtec selinoid gasket, cam seals, valve cover seal, spark plug seals and the grommets.
Im going to get it done next week
Old Feb 3, 2005 | 03:28 PM
AlxSiR7's Avatar
Default Re: B18C head oil leak (old_school_dohcvtec)
oh ok.. ill prob just do it myself.. seems easy enough
Old Feb 3, 2005 | 04:47 PM
jspec-integ Ls's Avatar
try checking your head, make sure your head isn't warped, just by the way you were trying to explain it. It sounded just like my problem where oil leaked out under the headand slipped through the headgasket and leaked over the b18c1 stamped, and once i pulled the head and had it checked it was the head that was warped. Try looking at your head to see if it's waroped or not.
Old Feb 3, 2005 | 05:19 PM
AlxSiR7's Avatar
Default Re: B18C head oil leak (jspec-integ Ls)
damn.. how can the whole head warp? that would suck!
Old Feb 3, 2005 | 05:21 PM
NightRiderS2K's Avatar
In-N-Out Burger
Im pretty sure the camplug is the culprit.
You can invest in an STR one (I've had it for 3 years...no leaks).
Old Feb 3, 2005 | 05:47 PM
AlxSiR7's Avatar
Default Re: B18C head oil leak (NightRider-gsR)
how is it any different than oem??
Old Feb 3, 2005 | 06:00 PM
Lord Helmet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AlxSiR7 &raquo;</TD></TR><TR><TD CLASS="quote">how is it any different than oem??</TD></TR></TABLE>
because the oem piece are known for deteriorating faster then aftermarket brand like STR or Golden Eagle.
Old Feb 3, 2005 | 06:54 PM
Built B16A's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NightRider-gsR &raquo;</TD></TR><TR><TD CLASS="quote">Im pretty sure the camplug is the culprit.
You can invest in an STR one (I've had it for 3 years...no leaks).</TD></TR></TABLE>
X2
Old Feb 4, 2005 | 06:52 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AlxSiR7 &raquo;</TD></TR><TR><TD CLASS="quote">thanks man so if it's not leaking around the vtec sol. then it should be the cam plug? #8??</TD></TR></TABLE>Or maybe the spool valve gasket #12?
I couldn't tell which of those 2 for mine, so I just got them all. They're not real expensive...
Old Feb 4, 2005 | 08:03 AM
AlxSiR7's Avatar
Default Re: (JimBlake)
just bought a metal cam seal with 2 o rings on ebay for $7, so hopefully this will fix the leak! but i work at a dealer so ill just order all the other possible gaskets if this doesn't do the fix. thanks again for all the help
Modified by AlxSiR7 at 12:35 PM 2/4/2005
Old Feb 4, 2005 | 01:16 PM
JDM_Spec's Avatar
i have the same problem
Old Feb 4, 2005 | 01:27 PM
AlxSiR7's Avatar
Default Re: (JDM_Spec)
http://motors.search.ebay.com/...spiZ2
$10 for most of em.. $25 if you want a logo on it
Old Feb 4, 2005 | 02:33 PM
Built B16A's Avatar
yeah, those are the ones... double o rings, and make sure not to tighten them down too much... just a **** hair past snug... they don't take much.
Old Feb 4, 2005 | 03:30 PM
AlxSiR7's Avatar
should i use tha hondabond sealent stuff with it or will it be ok just with the 2 o rings??
Old Feb 4, 2005 | 08:49 PM
Drian's Avatar
Which cam seal are you replacing? And you bought over ebay, do they come in a set of 2 or singles?
Old Feb 4, 2005 | 11:44 PM
Built B16A's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AlxSiR7 &raquo;</TD></TR><TR><TD CLASS="quote">should i use tha hondabond sealent stuff with it or will it be ok just with the 2 o rings??</TD></TR></TABLE>
yeah, use some hondabond... it wouldn't hurt.. just dont' crank down on those cap bolts too tight.. they arn't made for support, only a decent seal.. and once the aluminum is snugged down to the o rings.. the o rings make the seal... honda cam seals are notorious for leaking.
