how to fill a big hole
Old Feb 2, 2005 | 06:05 PM
contender's Avatar
Default how to fill a big hole
how would you fill a big hole with bondo if it's no a quater panel? do you have to weld a piece of to it and then bondo over or what?
Old Feb 2, 2005 | 06:09 PM
Bamex's Avatar
Default Re: how to fill a big hole (contender)
yea weld a plate to the back of the " BIG HOLE"
and then make it flush with bondo!
Old Feb 4, 2005 | 09:00 AM
CTR_ryan's Avatar
Default Re: how to fill a big hole (Bamex)
actually the best way would be to trace the hole and cut out a piece of material that is roughly the same thickness as what you are trying to fill. You can use a magnet to hold it into place while you tack weld it and then remove the magnet and finish welding the area. Then take a grind and grind down the high spots and finish up with an orbital sander. If you have done it right, then you won't need bondo except for a little bit of surface filler. You just have to be careful when you are welding to not heat the surface up too much, otherwise, it will distort your panel.
trancedroller
Apr 17, 2010 02:42 AM
avaldez
Welding / Fabrication
12
Jun 11, 2009 08:33 AM
4DRmafia
Paint and Body
10
May 18, 2007 02:36 PM
CBURKE
Jun 12, 2006 01:31 PM
Race Egr
27
Apr 20, 2005 01:05 AM
