What wire harness do I use?
Old Feb 2, 2005 | 05:32 PM
85mm LS VTEC's Avatar
Default What wire harness do I use?
I have a 90 Civic hatchback DX and I'm going to swap in a P28 ecu. I'm going to replace the O2 sensor and distributor to an OBD1 type on my LS/VTEC. I have the OBD0-OBD1 ecu jumper harness coming, so what engine harness do I need to finish the swap? A big thanks in advance .
Old Feb 2, 2005 | 10:24 PM
eda6's Avatar
Default Re: What wire harness do I use? (85mm LS VTEC)
you should use the 90 dx harness. Add wires for the dizzy, knock sensor and vtec. Also do a dpfi to mpfi conversion.
Old Feb 2, 2005 | 10:28 PM
Mach69's Avatar
Default Re: What wire harness do I use? (eda6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eda6 &raquo;</TD></TR><TR><TD CLASS="quote">you should use the 90 dx harness. Add wires for the dizzy, knock sensor and vtec. Also do a dpfi to mpfi conversion.</TD></TR></TABLE>
...and don't forget the 4 wire O2 sensor as well.
Like he said, the car needs to be wired for mpfi for the conversion harness to have a positive effect. Thats how the conversion harness works MPFI OBD0 -&gt; OBD1.
Old Feb 3, 2005 | 09:58 AM
Default Re: What wire harness do I use? (Mach69)
Is there a website you can refer me to so I can read up on how to do the mpfi conversion?
Old Feb 3, 2005 | 10:06 AM
manson's Avatar
search the forum and you'll get loads of instructions on how to do it.
hahagasdcrx's Avatar
http://www.fourthgenhatch.com/mpfi.html
theres a good write up on it with pics.
Do this dpfi-mpfi swap first, then buy a 0bd0-obd1 harness, then add those wires. Boomslang has conversion harnesses and great guy to help you if you have any questions.
mike93eh2
Apr 23, 2008 06:13 PM
Mr. Giggles
Jan 8, 2007 05:42 PM
De_tour
Nov 14, 2006 06:02 AM
CRseXy
Dec 27, 2004 05:36 PM
-slow ej-
Nov 25, 2003 03:18 PM
