Which drive shafts for my b16a2 swap into 92 HB?
Should i use the DA drive shafts that came with the motor, or do i use the DC shafts? Also which Intermediate shaft do i use?.. once again DC or DA? I have a YS1 LSD Cable tranny if that makes any difference.
TIA
TIA
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
you need to use the axles and intermediate shaft from the b16a. the other will not work.
TIA
TIA
if you are using a cable tranny a kit will be required (hasport), which in that case you will use 90-3 intermideate shaft with axles...
if you go the hydraulic route, then 94+GSR or 92 SiR intermideate shaft and driver side axle will be used, the passanger axle from also 94+ GSR or SiR or 90-3 Integra,
ABS axles are different, so are auto
Jackson....I did not get the wrong motor. THe JDM XSi came with a gen 2 b16a, and a cable ys1 lsd... that is why i wanted to know if i should use those shafts.
Adrian, thanks... i'll give you a buzz tomorrow night... i got a few quick questions for you about chipping
wheels01
Jun 3, 2005 10:58 PM
Combustion Contraption
Sep 8, 2004 05:51 PM
