rear sway bar with omnipower lca
Old Feb 2, 2005 | 04:02 PM
ablack934doorcivic's Avatar
Default rear sway bar with omnipower lca
it's a 93 4 door civic i just installed omnipower lca and coilovers and now my stock swaybar dosen't line up with the holes in the new lca the holes seem to low and the sway bar is too far away from the arms i could make this work if i had to but i was wondering if i did something wrong or what r my options
Old Feb 2, 2005 | 04:10 PM
ironlung78's Avatar
Default Re: rear sway bar with omnipower lca (ablack934doorcivic)
put the factory lca up to the new one..
if the holes are in the same spot, which i'm pretty sure they will be, then you have to make it fit.....Use a jack under the wheel to jack up each side while your lining everything up. Do one side at a time and should be all set
Old Feb 2, 2005 | 04:46 PM
wishingiam's Avatar
Default Re: rear sway bar with omnipower lca (sidesi)
yeah it's supposed to be like that, just make it work and don't forget to put the nut on the sway bar bolt
Old Feb 3, 2005 | 02:30 PM
Default Re: rear sway bar with omnipower lca (phuckyou)
Thanks alot i will make them work then
Mikes2000civicsi
Mar 27, 2008 09:02 PM
96 GSR-T
Suspension & Brakes
Mar 11, 2008 07:21 PM
. o 69 o .
Suspension & Brakes
40
Aug 23, 2005 09:49 PM
SweetChin
Apr 15, 2005 09:28 AM
spock_rocker
May 23, 2004 06:43 AM
