Please help me! ASAP!
Old Feb 2, 2005 | 03:19 PM
1SlowSi's Avatar
Default Please help me! ASAP!
As we speak im trying to put in a camber kit. I have a 99 Civic SI. I already removed the 2 bolts from the inside of the engine bay. There is one bolt that connects to the ball joint and goes through the A arm. How does that come out? It aint budging and the nut is already off. please help me out here.
Is that pressed in the a arm at all or does it just set it there and become stuck after driving a while again.?
Old Feb 2, 2005 | 04:44 PM
1SlowSi's Avatar
Default Re: Please help me! ASAP! (1SlowSi)
bump
Old Feb 2, 2005 | 07:52 PM
sickerhatch's Avatar
are you talking about the lower one near the bottom of the brake rotor? if you are then its not pressed on get a ball joint splitter and give it a good whack.but be careful not to tear the rubber boot.
Old Feb 2, 2005 | 08:36 PM
IN VTEC's Avatar
Default Re: Please help me! ASAP! (sickerhatch)
Any time I have to pop an upper balljoint, I usually end up tearing the boot with the fork splitter. I always have a few spare ones lying around for those occasions.
Old Feb 2, 2005 | 09:42 PM
1SlowSi's Avatar
Default Re: Please help me! ASAP! (IN VTEC)
on the U shaped thing (camber kit).. its that bolt thats connected to the ball joint. THere are 2 bolts that connect through the inside of the engine then that one that connect directly to the A arm. Not the bottom of the rotor. I cannot get that bastard to budge. SO a fork huh?
Old Feb 3, 2005 | 06:23 AM
1SlowSi's Avatar
i wish i could post a damn pic but I dont know how.
http://memimage.cardomain.net/...l.jpg
beatthisspeed69
Jul 12, 2007 02:32 AM
The DX Rex
May 29, 2005 05:12 PM
1SlowSi
Suspension & Brakes
Feb 3, 2005 01:43 PM
ilikemyaccord
Aug 29, 2003 02:48 PM
nick.na
Apr 14, 2003 11:34 AM
