Where did my oil go? Help!!
Old Feb 2, 2005 | 03:05 PM
AlphaQup's Avatar
Default Where did my oil go? Help!!
Here's the deal.
Ever since I got my GSR. I've probably done 4-6 oil changes (changed every 2500-3K miles). I'm sure the previous owner used cheap **** they use at Jiffy Lube, since he didn't know **** about cars. I've only been using Mobil1 Full Synthetic 10w30.
Since my last 2 oil changes, I've knowticed that every 1500 miles after the oil change, I lose ~ 1qt (burned?). I don't knowtice any soot or black residue around my bumper area near the tailpipe, nor any white smoke while driving.
So I'm thinking it's due to the change from regular oil to full synthetic oil. But that's just a guess. My motor runs strong. It's only got 94K on it. Anybody got any idea's how I should go about solving this problem?
Nick
Old Feb 2, 2005 | 05:43 PM
screaminvtec's Avatar
Default Re: Where did my oil go? Help!! (AlphaQup)
my car was doing the same thing. i decided to try castrol gtx high mileage. it cut down on the oil burn off alot. i put on 1500 mile since oil change and no loss. i would say you can try that it worked for me. if you want to stay synthetic maybe try royal purple. i heard that if you burn oil with royal purple something is wrong with the car. good luck.
Old Feb 2, 2005 | 07:13 PM
RedlinedVTEC's Avatar
Default Re: Where did my oil go? Help!! (screaminvtec)
You should definately stay synthetic. You never switch back once you run synthetic.
Try replacing the pcv valve, and checking for oil in the coolant and vice versa. Also oil consumption is common in all vehicles. So if your not blowing out smoke then you'll be ok as long *** you keep it topped off. BTW how many miles on the motor?
Old Feb 2, 2005 | 08:39 PM
AlphaQup's Avatar
Default Re: Where did my oil go? Help!! (RedlinedVTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by screaminvtec &raquo;</TD></TR><TR><TD CLASS="quote">my car was doing the same thing. i decided to try castrol gtx high mileage. it cut down on the oil burn off alot. i put on 1500 mile since oil change and no loss. i would say you can try that it worked for me. if you want to stay synthetic maybe try royal purple. i heard that if you burn oil with royal purple something is wrong with the car. good luck.</TD></TR></TABLE>
What's the mileage on your motor?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedlinedVTEC &raquo;</TD></TR><TR><TD CLASS="quote">You should definately stay synthetic. You never switch back once you run synthetic.
Try replacing the pcv valve, and checking for oil in the coolant and vice versa. Also oil consumption is common in all vehicles. So if your not blowing out smoke then you'll be ok as long *** you keep it topped off. BTW how many miles on the motor?</TD></TR></TABLE>
Like I said above, the motor's got 94K. I want to stay synthetic, but I am not going to spend 8-10 bucks a bottle of royal purple. Don't mean to sound clueless, but where is the pcv valve? On the intake manifold right? haha
Oh and there is no oil in my coolant. My headgasket is still good.
Anybody else got any more ideas/recomendations?
Old Feb 2, 2005 | 09:30 PM
notstock93's Avatar
valve seals?
VTEC engines have a reputation for burning oil if ran hard.
Do a compression/leak-down test. If its all fine then you don't really have any problems. If it starts to consume large quantities, then you may want to be concerned.
Old Feb 3, 2005 | 12:42 AM
Malgerus's Avatar
False. This is a very common myth.
The only disadvantage to going back to "normal" oil is that you may experience a little gasket leak. My brother went from N/A with 10w30 synthetic to F/I with 10w30 conventional, with no problems.
Old Feb 3, 2005 | 04:35 AM
Default Re: Where did my oil go? Help!! (Mr. S)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. S &raquo;</TD></TR><TR><TD CLASS="quote">
That's exactly the reason you don't want to switch back to conventional. No leak is a good leak. All you're doing is creating issues for down the line.
Old Feb 3, 2005 | 04:49 PM
i just rolled over 80k
Old Feb 3, 2005 | 05:04 PM
AlphaQup's Avatar
Anybody else got answers? I just need more input.
ac_attak
Oct 26, 2006 06:34 PM
redLUDEs2k1
Oct 12, 2005 10:21 AM
oMek
Sep 21, 2003 03:49 PM
Behan
Sep 9, 2003 05:10 AM
TypeR01-424
Aug 17, 2001 07:51 AM
