clutch
Old Feb 2, 2005 | 02:40 PM
starbury's Avatar
Default clutch
im need to put in a clutch for my 2000 si, eventually gonna add cams pistons headers intake manifold but right now the motor is stock, what brand clutch, stage, and flywheel should i get? the motor is gonna be stock for a while so do i even need a flywheel?
Old Feb 2, 2005 | 02:43 PM
numbnuts22715's Avatar
it would be best to change out flywheel and clutch at same time so itll grab better. As for the clutch, either exedy or act. stage 2-3 in my opinion. Just find a site that says how much torque they are capable of and see with that. the stage 2 should be fine though, I think. Get a second opinion, Im kinda a newb still as I dont know anything from first hand since I havent modded my ride yet
Old Feb 2, 2005 | 02:46 PM
_Cyclone_'s Avatar
Default Re: (numbnuts22715)
I'm sure a stage 2 will be plenty sufficient.
Old Feb 2, 2005 | 03:15 PM
Contraband's Avatar
If your gonna do the clutch, you might as well do the flywheel at the same time since your gonna open it up anyway. Save yourself a lot of time and sweat, money too if your gonna get it done by someone. Just something to think about. Im spinning a pro-lite flywheel with a 6 puck clutch, the only problem is Im still using a stock pressure plate, so the clutch is soft as hell. Now i gotta go back in and change it. Sucks because I thought I was done.
Old Feb 2, 2005 | 03:33 PM
96_civ's Avatar
Default Re: (LS95eg)
i agree do both, im about to get mine done in a week or 2. there is a guy on here named Tony he's gonna get me an act clutch and act 12lb flywheel for $480 but thats for my d16 (sohc) but im sure he can hook you up too.
Old Feb 2, 2005 | 03:35 PM
96_civ's Avatar
Default Re: (96_civ)
his username is 3RdT
your welcome tony, im tryin to get you some business here
HondaCivic2006
Honda Civic (2006 - 2015)
36
Jan 17, 2014 06:16 PM
OBDII Integra
Sep 30, 2009 04:04 PM
b16hybridsol
Honda S2000
12
Jul 3, 2008 11:57 AM
allstockb18c
Jul 3, 2005 12:44 PM
beandip
Nov 23, 2003 11:31 AM
