Question about Earl's SS brake lines..
Old Feb 2, 2005 | 01:30 PM
mstewar's Avatar
Default Question about Earl's SS brake lines..
What is the purpose of the spring thing on the end? why do other SS brake line manufacturers not have these?
Thanks!
Old Feb 2, 2005 | 02:21 PM
bryant's Avatar
Default Re: Question about Earl's SS brake lines.. (mstewar)
Spring thing? My earls dont have that.
Old Feb 2, 2005 | 04:14 PM
mstewar's Avatar
Default Re: Question about Earl's SS brake lines.. (Bryant)
see pic:
Old Feb 2, 2005 | 04:16 PM
Bbasso's Avatar
WTH ?
got a better veiw?
Old Feb 2, 2005 | 06:43 PM
fullraceacura's Avatar
it is probably some fitting that some crazy *** car uses to bolt up, like a toyota or soemthing
Old Feb 2, 2005 | 10:04 PM
mstewar's Avatar
Default Re: Question about Earl's SS brake lines.. (Bbasso)
not really a better pic.. here's the link where I pulled the pic from though..
http://www.modacar.com/product...DABRL/
same pic here as well though:
http://store.racerwheel.org/ra....html
Old Feb 3, 2005 | 04:47 AM
Bbasso's Avatar
I really can't see what kinda contraption that is But I bet the pic is a general one that they use for the product...
I would bet that the ones for the ITR look like normal ends.
If you order them, make sure the place you get them from has a good return policy in case that thing is on and does not work with your caR.
Old Feb 3, 2005 | 06:30 AM
mstewar's Avatar
upon further review, I'll probably be ordering a set of Techna Fit's from King Motorsports.. They're coated and about the same price..
Still weird though.. no idea what that spring thingy is..
Old Feb 3, 2005 | 07:10 AM
JeffS's Avatar
This may just be a stock picture.
If I had to guess, I'd say that it's there to prevent fatigue of the crimp joint on that end. Typically, you see a heavier rubber/plastic wrap extending down the end some to help control flexing - just as some, more expensive, water hoses (for your yard) have a spring coiled around the outside of the hose end.
Old Feb 3, 2005 | 10:47 AM
nemesis0104's Avatar
Default Re: Question about Earl's SS brake lines.. (JeffS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JeffS &raquo;</TD></TR><TR><TD CLASS="quote">This may just be a stock picture.
If I had to guess, I'd say that it's there to prevent fatigue of the crimp joint on that end. Typically, you see a heavier rubber/plastic wrap extending down the end some to help control flexing - just as some, more expensive, water hoses (for your yard) have a spring coiled around the outside of the hose end.</TD></TR></TABLE>
damn you beat me to it...
Old Feb 3, 2005 | 10:56 AM
mstewar's Avatar
ended up getting StopTech's this morning..
And I'll be featuring their logo on my car..
Old Feb 3, 2005 | 11:39 AM
johnzm's Avatar
BTW- worked on a honda civic, saw these same funky fittins, and they also come with special fittinfs that bolt to the strut.
they said earls on the crimp fitting on the line. like dude above said, help sontrol the line so maybeit wont get stuck in ur wheel
starbai
Suspension & Brakes
14
Oct 10, 2008 08:09 PM
mullet eater
Suspension & Brakes
Aug 1, 2008 03:18 PM
bjfisher
Suspension & Brakes
Feb 3, 2006 04:41 PM
MidNiteMysT
Jul 7, 2003 07:25 PM
