Replacing ground wire on valve cover????
What gauge wire should you use to replace the nasty rust colored wire on the valve cover, also what kind of ends....I know its a worthless question but...nice day=clean engine bay.
Soak the wire in a 50/50 mix of muratic acid and water for like 10 minutes. It'll be shining like new.
Remember to pour the acid in the water, don't pour the water into acid.
PS- You can also use this for your tranny ground, valve cover nuts, etc. Works great.
[Modified by Mike K, 10:40 AM 1/15/2002]
civicgsr499
Jun 5, 2009 11:41 AM
