need more rpm?
Old Feb 2, 2005 | 07:48 AM
crxdonwon's Avatar
Default need more rpm?
I have a pm6 ('89 ecu) on my rex ('90 rex) with a 92-95 civic ex intake manifold and injectors and fuel rail, si dizzy, si cam, port and polished head, head has been shaved 1mm, all on a rebuilt d15b2
The rev limit now is currently 6500 and I would like it to be 7200 to 7800, ok if I could get it into the 8000 that would be sweet to, but my question is,
Can I rewire something at the ecu to give it a higher rev limit?
I have heard this, and that is the only reason why I ask. If it can be done I would like to give it a try because the motor pulls hard from 3800 to rev limit (6500), and I would like to see if it would keep pulling through the higher rpms also. I don't think that my little car is seeing it's full potential.
Old Feb 2, 2005 | 08:02 AM
Ef-er's Avatar
Default Re: need more rpm? (civicdonwon)
the pm6 should not cut off at 6500
mine used to take me to 7200
yes there are chips u can get
or u can look into another ecu like 89 teg or zc if u want more
Old Feb 2, 2005 | 08:11 AM
crxdonwon's Avatar
Default Re: need more rpm? (ChineseGuy)
I heard only the '91 si ecu went up to 7200, not only that, but my ecu came out of an automatic. Is there some wire swapping that I can do? Will the '91 teg not make it run hella' rich?
Old Feb 2, 2005 | 08:17 AM
PHOBIA's Avatar
ther eis your problem. its an auto. yo need to get it chipped or switch to a si ecu.
Old Feb 2, 2005 | 08:20 AM
crxdonwon's Avatar
Default Re: (PHOBIA)
No wire swaping, just ecu swaping, right?
Old Feb 2, 2005 | 08:31 AM
PHOBIA's Avatar
correct.
Old Feb 2, 2005 | 08:33 AM
crxdonwon's Avatar
pershitatit man, I'll probably go and get another ECU Soon
Jay.D.Em!
12
Feb 9, 2006 03:41 PM
StupidSlowRSX
Nov 29, 2003 12:35 PM
tgod1020
Oct 2, 2003 09:25 AM
altoid
Oct 7, 2002 06:51 PM
biggs
Apr 24, 2002 12:09 PM
