cam seal
Old Feb 2, 2005 | 04:06 AM
diversegsr's Avatar
Default cam seal
this is a stupid question but where is the cam seal and how do you replace it??
Old Feb 2, 2005 | 04:35 AM
NJIN BUILDR's Avatar
Default Re: cam seal (diversegsr)
There is a seal on each camshaft behind the cam gears.There is also a seal on the trans end of the head which is more of a vc seal,but it is also called a cam seal.Its solid rubber stock and tends to leak when it gets old.There are several companies making aluminum ones with o-rings for about $15-$20.
Glenn
Old Feb 2, 2005 | 08:27 AM
jdmcx's Avatar
Default Re: cam seal (NJIN BUILDR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJIN BUILDR &raquo;</TD></TR><TR><TD CLASS="quote">There is a seal on each camshaft behind the cam gears.There is also a seal on the trans end of the head which is more of a vc seal,but it is also called a cam seal.Its solid rubber stock and tends to leak when it gets old.There are several companies making aluminum ones with o-rings for about $15-$20.
Glenn</TD></TR></TABLE>
Modified by jdmcx at 3:57 PM 2/2/2005
JThrasher79
Jan 10, 2006 12:30 PM
blueintegra90
May 18, 2004 12:47 PM
DefiantGSR
Feb 20, 2004 08:43 PM
