Tranny Problems
Old Feb 1, 2005 | 11:56 PM
ServiceAdvisor's Avatar
Default Tranny Problems
Yeah, I think this is a problem, but my question is can it be fixed?
http://www.we-todd-did-racing....D.jpg
Looks like the pin broke and then all went to hell. - Darrell
Old Feb 2, 2005 | 02:13 AM
BizUmp
Old Feb 2, 2005 | 06:43 AM
jlicrx's Avatar
Default Re: (DOHCZCCRXSi)
looks like you need a new front half of case - can't tell from picture if the differential carrier is o.k.
Old Feb 2, 2005 | 12:35 PM
The diff casing is fine aside from the pieces of broken pin on each side which I have already tapped out. But is it safe to use the transmission with that chunk of it missing along the bar there? - Darrell
Old Feb 2, 2005 | 07:06 PM
jlicrx's Avatar
looks like it is broken in 2 places where the shift arm shaft goes thru the case - not much left to hold the shaft in place - i would just get a different case front half and swap everything over - what transmission is it?
Old Feb 2, 2005 | 09:34 PM
Its a 89 Si tranny. I can get ahold of a 91 LX/DX tranny thats used, would switching to the Si gears be as easy as just mounting the Si Mainshaft/reverse arms/idler arm/gears ect. into the DX transmission? I have the haynes manual, just looking for solid info so I can have this car back on the street by saturday. I'm off Friday/Saturday and I've been driving my 96 DX Coupe beater for almost 3 weeks. - Darrell
Old Feb 3, 2005 | 02:26 AM
3:30am and I gotta work at 10am Bump!
RACEPAK
Welding / Fabrication
16
Jul 13, 2013 05:39 PM
UrbanFuturistic
Apr 11, 2005 07:46 PM
SamuelK
Jul 9, 2004 11:37 AM
