Quick Question about a 16" Rota's right offset and tyre size.
Old Jan 15, 2002 | 04:55 AM
nEoMuGen's Avatar
Default Quick Question about a 16" Rota's right offset and tyre size.
Guys, please just drop a quick line. Thanks!
I am buying 16"x7, 5x114.3 Rota Slipstreams for my stock ride height ITR.
The question is: Should I get 40+ offset or 45+ offset.
The tyres that will be wrapping them are S-03s, what size should I use?
Is 205/50/WR-16 ok?
This will be my street setup...and if for some special circumstances, it may see some light autox/track. I know Azenis are good, but I want to opt for the best. Besides, S03 have 240 thread wear as oppose to Azeni's 200....I don't want to folk out any more money buying street tires within the next two years.
Old Jan 15, 2002 | 06:34 AM
yoshi234's Avatar
I shoot brides
Default Re: Quick Question about a 16" Rota's right offset and tyre size. (nEoMuGen)
offset will depend on which tyre size you get
45 offset for 215 or 225 section width
40 offset for 205 section width
don't get 205/50R16 b/c the tyre will be t00 tall.
215/45R16 or 205/45R16 is the best size.
-y
Old Jan 15, 2002 | 07:15 AM
RATEDR's Avatar
Default Re: Quick Question about a 16" Rota's right offset and tyre size. (we-todd-did)
y- what about the 15" rota running a 205/50 tire...use the 40 mm off set?
Old Jan 15, 2002 | 09:02 AM
DutchITR1689's Avatar
Stock offset is 50 mm, right?
Why is a 40 mm or 45 mm better?
Old Jan 15, 2002 | 12:01 PM
nEoMuGen's Avatar
-y
Yosh.....I ran through Tirerack quickly and discovered that they don't have 215 or 205/45....the only one came close is a 225/45/16. I do not want any rubbing, so
please help me out. Go here and click on "price&sizing"
http://www.tirerack.com/tires/bridgestone/bs_s03.jsp
[Modified by nEoMuGen, 9:05 PM 1/15/2002]
[Modified by nEoMuGen, 9:07 PM 1/15/2002]
Old Jan 15, 2002 | 12:19 PM
yoshi234's Avatar
I shoot brides
hrm, I dont' see S03's sizes that will work well w/ your TE37s. If these are only for street, then the Azenis will last you two years easily.
you could go w/ 225/45R16 *IF* you had 50mm offset, but I"m assuming your rims are about a 43 offset which won't work.
Old Jan 15, 2002 | 12:25 PM
nEoMuGen's Avatar
sorry, I am using cheapo Rota 16x7, with the options of 40+ or 45+ mm offset.
If so...then I'll go with the Azenis.
215-45 Azenis = no rubbing?
[Modified by nEoMuGen, 9:25 PM 1/15/2002]
Old Jan 15, 2002 | 12:27 PM
yoshi234's Avatar
I shoot brides
00ps, I got cornfused w/ somebody else's te37
get the 45 offset w/ 215/45R16
Old Jan 15, 2002 | 01:47 PM
nEoMuGen's Avatar
Also....since you said that 205/50-16 is too "tall" for my car. Is it just the looks? If it is, I can buy some Spoon springs to lower my car abit to accompany to height.
Will it rub?
Old Jan 15, 2002 | 01:52 PM
yoshi234's Avatar
I shoot brides
t00 tall = hurts performance (throws off speedo, car will feel slow...)
Old Jan 15, 2002 | 01:53 PM
nEoMuGen's Avatar
sigh....I'm always a big fan of Bridgestone. That's a disappointment!
Old Jan 15, 2002 | 01:57 PM
yoshi234's Avatar
I shoot brides
If it must be bridgestone, then get RE010s in 215/45R16 (but the ones they sell in US are made to be front tyres for the NSX - $$$)
Old Jan 15, 2002 | 02:00 PM
nEoMuGen's Avatar
Oh no! RE010s....(runs away)
I will never buy a set of these again. They aren't worth the price for low wear and incapability of wet traction for a street tire. They are not good for autox/road either.
Old Jan 15, 2002 | 04:41 PM
GSR18's Avatar
Does anyone know if the Azenis 215-45-16 will rub with my 16" wheels with a +40mm offset? This is going on my GSR.
Old Jan 16, 2002 | 02:11 PM
Reid's Avatar
Global Moderator
What are you talking about?
Old Jan 16, 2002 | 06:59 PM
nEoMuGen's Avatar
Default Re: Quick Question about a 16" Rota's right offset and tyre size. (Reid)
The higher priced RE010 does not offer more performance than the cheaper S03 and Azenis. They lasted only 12,000mi on me, their thread wear is like 160 compare to S03's 240 and Azenis's 200. It almost got me killed in rain, and from many ppl's experienced, S03 and Azenis are equal if not better than RE010 on dry and definetly better in wet. So that's why I said I'll never buy another set of RE010 again. Off the record, tireracks' customer survey reveals total satisfaction of 7.3 points for the RE010 and 9.x+ for the S03.
And my sidwalls are balded after 1 track day and several autox. My car is dangerous to drive on the streets now, it shake badly and I can't align them because my tyres are out of shap. I definetly need a new set of tyres.
[Modified by nEoMuGen, 4:05 AM 1/17/2002]
Old Jan 16, 2002 | 07:04 PM
Reid's Avatar
Global Moderator
To be fair, you can't blame this on the tires.
Old Jan 16, 2002 | 07:07 PM
nEoMuGen's Avatar
It had problem stopping, and I wasn't even driving fast.
goldenmustache
Jun 19, 2010 04:13 PM
93civicEX
Mar 31, 2006 08:16 AM
Adi
Sep 30, 2003 01:41 PM
drvfast
Mar 5, 2003 07:20 AM
GSR18
Oct 26, 2001 07:59 PM
