This should be an Easy Question
My 93 EX has two belts. One appears to be for the power steering pump, and the other for the alternator and a/c compressor. The alternator belt is a little loose and is slipping when I first start the car. It slips more if I try to run the a/c. Right now that isn't a big problem because it hasn't been above 19 degrees here in weeks, but soon it will warm up and I'll be needing my a/c. Is there an adjustment for that belt? I don't see a tension pulley so I'm assuming it isn't a normal serpentine setup.
This is the car I'm working on.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iakona »</TD></TR><TR><TD CLASS="quote">yes, you can adjust the tension on your alternator belt.</TD></TR></TABLE>
