rear disc conversion 90 civic si (did a search)
Old Feb 1, 2005 | 09:10 PM
cutt's Avatar
Default rear disc conversion 90 civic si (did a search)
someone please correct me if I have anything wrong: parts list
90-93 teg trailing arm assembly
94 teg e-brake cable TOLD IT WAS A PERFECT FIT
90-93 teg prop valve 40/40
90-93 teg booster
90-93 teg master cylinder 15/16
SS lines (WHAT COMPANY)
This is what I collected from my search If theres anything wrong or anything else I need please let me know Thanks for all your help
AND EVERYTHING BOLTS RIGHT UP AND FITS !!!!
Old Feb 1, 2005 | 09:26 PM
CRX-SIR's Avatar
Default Re: rear disc conversion 90 civic si (cutt)
Thats a good parts list. Everything should bolt up if you put it together right.
Old Feb 1, 2005 | 09:49 PM
cutt's Avatar
Default Re: rear disc conversion 90 civic si (b18a1integ)
BUMP
Old Feb 1, 2005 | 09:51 PM
kulangot's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18a1integ &raquo;</TD></TR><TR><TD CLASS="quote">Thats a good parts list. Everything should bolt up if you put it together right.</TD></TR></TABLE>
Old Feb 1, 2005 | 09:56 PM
turboZChatch's Avatar
Default Re: rear disc conversion 90 civic si (sirq2u)
I used 90-93 teg ebrake cables and had no problems
Old Feb 1, 2005 | 10:15 PM
GRAND CIVIC's Avatar
Default Re: rear disc conversion 90 civic si (turboZChatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboZChatch &raquo;</TD></TR><TR><TD CLASS="quote">I used 90-93 teg ebrake cables and had no problems</TD></TR></TABLE> Sounds like you have all the parts you need .
Old Feb 1, 2005 | 10:31 PM
SIRef9[831]'s Avatar
Default Re: rear disc conversion 90 civic si (GRAND CIVIC)
if u need a step by step on how to there is one in jdmcivic.com on the ef section.
Old Feb 2, 2005 | 02:39 AM
90civichbsi's Avatar
Default Re: rear disc conversion 90 civic si (SIRef9[831])
yep sounds good, i used 90-93 cables and they worked perfect, you may wanna get good trailing arm bushings while your there, either stock ones or energy suspension. ya may wanna add pads and rotors too the list, kinda important.
also for ss brake lines i got goodridge ones from http://www.fast-turbo.com or stan as he goes by here on h-t.
Weapon_R
11
Jun 4, 2005 09:15 AM
Andres-eh2
Apr 18, 2004 07:33 AM
ironchef25
33
Mar 5, 2004 05:04 AM
AnNiMosSiTY
Oct 2, 2003 10:24 AM
