88 Crx USDM Cluster Pinout * SEARCHED*
Old Feb 1, 2005 | 07:09 PM
BaYoNAiM's Avatar
Default 88 Crx USDM Cluster Pinout * SEARCHED*
Does anyone have the pinouts for an 88 crx cluster?
I searched already and the nearest thing is the EK cluster swap pictures which are not accurate for the 88, it may be the 89 depicted.
My cluster does not light. I tested the bulbs with direct 12v and ground and it worked, so I know its not the bulbs. Then I tested the dimmer switch.
The dimmer switich consist of 3 wires; solid red, solid black, and red with black.
The solid red and red with black acted the exact same in voltage. With the car lights on I got a reading of 4.3v or so with the dimmer on full, as I decreased the dimmer the volts raised to a maxium of 11.4v with the car off.
Does anyone know why?
My oil pressure light also does not turn on when I start the car. Can this be the effect of a bad oil pressure switch?
Thanks in advance.
Old Feb 1, 2005 | 07:24 PM
BaYoNAiM's Avatar
Default Re: 88 Crx USDM Cluster Pinout * SEARCHED* (BaYoNAiM)
ttttt
Old Feb 1, 2005 | 07:30 PM
BaYoNAiM's Avatar
Help?
Old Feb 2, 2005 | 08:39 PM
BaYoNAiM's Avatar
Anyone?
Old Feb 2, 2005 | 08:42 PM
88ED8's Avatar
http://www.ef-honda.com/main/viewtopic.php?t=1400 scroll down (usdm '88-'89 clips)
Old Feb 2, 2005 | 10:48 PM
BaYoNAiM's Avatar
Default Re: 88 Crx USDM Cluster Pinout * SEARCHED* ('89ED8)
I looked there already. I stated this in my first post. They do not match up to mine. I think that may depict the 89 models. I am missing one pin on each connecters not just one. And the wire colors do not match either.
Thanks though for actually responding. Half of H-T seems to be dead or at least blind.
Old Feb 28, 2005 | 05:40 PM
Loaded Butane's Avatar
I need to know this also.
I might go see if the honda dealer can give me a printout or something.
Old Mar 5, 2005 | 02:32 PM
99teggsr's Avatar
Default Re: 88 Crx USDM Cluster Pinout * SEARCHED* (Loaded Butane)
I just tried wiring up some gsr cluster plugs to my 88 usdm HF cluster wires, but also ran into the problem that the ef-honda.com is incorrect info. I am going to check out my Helms when I get to the garage to find the pin outs. will post if I am successful.
Old Mar 7, 2005 | 07:21 PM
Default Re: 88 Crx USDM Cluster Pinout * SEARCHED* (99teggsr)
Let us know
Old Mar 8, 2005 | 08:21 AM
99teggsr's Avatar
Well im looking at the wiring diagram right now. Im not good at reading electric diagrams, are any of you ?? if so I can scan or take a pic of the page in my helms and you could probably figure out the pin outs.
Old Mar 8, 2005 | 10:19 AM
99teggsr's Avatar
Heres the wiring diagram, if any of you can decifer this It would be greatly appreciated.
Old Mar 8, 2005 | 10:29 AM
HatchBox's Avatar
Skoobie no more...
edit- wrong diagram
Old Mar 8, 2005 | 10:31 AM
99teggsr's Avatar
Default Re: 88 Crx USDM Cluster Pinout * SEARCHED* (HatchBox)
Thanks, but all us 88 owners have realised that diagram is wrong. It is for a 89 and who ever made it just assumed 88 is the same, not true. read up a few replys and you will see..thanks anyway though
Old Mar 8, 2005 | 11:18 AM
CrowerRex's Avatar
Here you go,
88 crx Connector 709 / 12 Pin
01-green/blue - left turn signal
02-yellow - switched power
03-yellow/white - fuel gauge
04-yellow/red - speed sensor
05-green/orange - check engine light
06-red/black - dash lights
07-red - dash lights
08-empty
09-black/yellow - switched power
10-white/blue - Low voltage
11-blue - tach
12-yellow/green - water temp gauge
88 crx Connector 710 / 8 Pin
01-black - ground
02-yellow/red - oil light
03-empty
04-green/red - emergency brake light
05-blue/yellow - ? .....Driver Door Light MAYBE
06-red/blue - high beam light
07-green/black - hatch light
08-green/yellow - right turn signal
Old Mar 8, 2005 | 11:27 AM
99teggsr's Avatar
Default Re: 88 Crx USDM Cluster Pinout * SEARCHED* (CrowerRex)
Thanks crowerrex, but just like the image on ef-honda.com those colors are wrong. Should I just assume the pins on the 88 are the same function, just different colors ?? I cant believe even the Helms manual is wrong!
Old Mar 8, 2005 | 11:33 AM
CrowerRex's Avatar
I did a 00 ITR cluster swap into my 88 crx si here about 5 months ago and ued these pinout locations and they worked perfectly, I ignored the colors as some are wrong. Let me know if you need to know anything else.
Old Mar 8, 2005 | 11:59 AM
99teggsr's Avatar
Just to clear everything up, is this what all you guys with 88's clips look like ??
Old Mar 8, 2005 | 12:04 PM
CrowerRex's Avatar
minus the top blue plug thats what mine looks like.
Old Mar 8, 2005 | 12:09 PM
99teggsr's Avatar
Great, the crx part of it is figured out, but do you have cluster pinouts for GSR plugs ??
Old Mar 8, 2005 | 12:18 PM
CrowerRex's Avatar
fill your boots man
94-01 GSR:
13 Pin connector:
1)Blue- Tachometer
2)Geen/Orange-Check engine
3)Yellow/Orange-Oil Light
4)Not Used
5)White/blue-Volts
6)not used
7)Yellow/green-Water Temp.
8)black-ground
9)Red/Blue- cruise(not used unless you have it)
10)Yellow-12vPower
11)Not Used
12)Not Used
13)Not Used
16 Pin connecter
1)Green/red- E brake
2)red/Green-High Beam
3)Green/Yellow-Right Turn signal
4)Green/Blue Left turn signal
5)not Used
6)black/yellow-12vPower
7)Red/Black-Power
8)Red-12vpower
9)blue/Red-ABS(not used unless you have it)
10)green-Trunk Light
11)Orange-VSS
12)not used
13)Blue/White-Low Feul(not used unless you have it)
14)Yellow/white-Feul Gauge
15)Green/Red-door
16)red/blue-seat belt
Old Mar 8, 2005 | 12:24 PM
99teggsr's Avatar
thanks crowerrex!!!!! Im emailing the admin over at ef-honda.com to fix the article.
Ecobox Racer
Apr 1, 2017 07:45 PM
bbarbulo
May 19, 2016 02:58 AM
cklauj207
Oct 7, 2012 05:31 AM
crxrider
Aug 21, 2007 02:59 PM
