97 del sol, OBD I or II
Old Feb 1, 2005 | 07:06 PM
94b16delslow's Avatar
Default 97 del sol, OBD I or II
Is the 97 california del sol OBD I or II because it does not have a OBD II standard port which after 96 was suppost to be OBD II compliant and still uses the flashing MIL light to flash codes. I need to know this cause i want to swap my 97 d16 with a b16 from a 94 which is OBD I. If it is im just going to get a crx or a hatch and put it in that.
Thanks a lot
Old Feb 1, 2005 | 07:26 PM
AzntaggeR's Avatar
TSPeed Factory
Default Re: 97 del sol, OBD I or II (94b16delslow)
its obd2
Old Feb 1, 2005 | 08:08 PM
dantastic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94b16delslow &raquo;</TD></TR><TR><TD CLASS="quote">Is the 97 california del sol OBD I or II because it does not have a OBD II standard port which after 96 was suppost to be OBD II compliant and still uses the flashing MIL light to flash codes. I need to know this cause i want to swap my 97 d16 with a b16 from a 94 which is OBD I. If it is im just going to get a crx or a hatch and put it in that.
Thanks a lot</TD></TR></TABLE>
obdII cars use the flashing MIL also. if you can't find the obd2 scanner port, ask the dealer. btw, you won't be able to legally swap your car unless you convert the b16 to obdII spec
Old Feb 1, 2005 | 08:12 PM
skip.two's Avatar
96-97 Del Sol's are OBD2a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dantastic &raquo;</TD></TR><TR><TD CLASS="quote">btw, you won't be able to legally swap your car unless you convert the b16 to obdII spec</TD></TR></TABLE>
wouldn't his swap still not be legal? older motor into newer car.
try to get a B16A2 from a 96-97 Del Sol VTEC, or 99-00 Civic Si.
Littleguy00
Feb 8, 2016 10:16 AM
o1gser
May 26, 2009 04:00 PM
teler86
Oct 8, 2006 06:25 PM
TeknoGroover
Apr 10, 2005 03:36 PM
96civich22
Jan 16, 2003 06:26 AM
