ITR owners' opinions on tune up a low miles ITR
Old Feb 1, 2005 | 06:04 PM
Biloxi's Avatar
Default ITR owners' opinions on tune up a low miles ITR
I have a '97 ITR with 27k miles. I wonder if I should do the tune up like timing belt, all belts change, water pump....etc? I searched the HT that most of you said that the OEM belt is good for 105k miles. But the question I have is the car is about 8 years old but hardly driven much. Therefore is major tuneup needed for the B18C5?
Thanks!
Old Feb 1, 2005 | 06:08 PM
rough_draft's Avatar
97itr with 22k is not low miles
Old Feb 1, 2005 | 06:21 PM
Cosworth's Avatar
Default Re: ITR owners' opinions on tune up a low miles ITR (Lordkoo)
Better safe than be sorry.
I would definitely change out the timing belt. Isn't it 105k miles or 8 years? Belt become brittle after a while. Better to spend $500 for t.b. & water pump, then blow up a motor, ya know?
Old Feb 1, 2005 | 06:31 PM
Reid's Avatar
Global Moderator
Default Re: ITR owners' opinions on tune up a low miles ITR (Cosworth)
I would replace the belts (both accessory and timing), fuel filter and the water pump.
I would also do a valve adjustment at this time.
Old Feb 1, 2005 | 06:54 PM
Rednas's Avatar
Default Re: ITR owners' opinions on tune up a low miles ITR (Reid)
are you selling it?
Old Feb 1, 2005 | 07:00 PM
totsie7944's Avatar
goo ahead and do it, specially in the cold if the belt if gettign brittle like others have said.
I just had a belt break on me and it put me over 2000 back.... I am poor now. But I also went tothe dealership and they robbed my blind.
Old Feb 1, 2005 | 07:26 PM
KayOs's Avatar
I would do the scheduled maintanance only (30K).
Old Feb 1, 2005 | 07:37 PM
Bbasso's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reid &raquo;</TD></TR><TR><TD CLASS="quote">I would replace the belts (both accessory and timing), fuel filter and the water pump.
I would also do a valve adjustment at this time.</TD></TR></TABLE>
&lt;--- thinking the same thing.
Old Feb 4, 2005 | 10:13 AM
Biloxi's Avatar
Default Re: ITR owners' opinions on tune up a low miles ITR (Bbasso)
Thank you all. Majority has spoken. I will go ahead do all the belts change, fuel filter, tranny...etc.
Old Feb 4, 2005 | 10:24 AM
Willard's Avatar
post pictures when you do the work.
low mileage CW =
square_1
13
Mar 7, 2007 10:10 AM
ildknyli
Apr 12, 2006 10:36 PM
integraguy2001
Aug 2, 2004 12:50 PM
N~FaMouSKhMerBoi
Jul 3, 2003 02:55 PM
animated_life
Oct 22, 2002 09:48 PM
