Cluster Gone Bad and rev limiter in a 90 accord dx 5 speed
Old Feb 1, 2005 | 05:37 PM
younbud's Avatar
Default Cluster Gone Bad and rev limiter in a 90 accord dx 5 speed
Speedometer, tach, and rev limter are not working i went to a shop and they said that it could be the ecu but i dont think that is just right i was wondering what you think
thank you
Old Feb 1, 2005 | 05:43 PM
The_Todd's Avatar
Farts in the shower
Default Re: Cluster Gone Bad and rev limiter in a 90 accord dx 5 speed (younbud)
Are you throwing any CEL's (check engine light)...if your cluster won't show anything it might not show cel's or anything. First thing I would check is your fuses and relays...then if nothing there go to the passenger side of the car and pull back the carpet to see if your ecu is flashing a code; refer to basic guide stickied up top for code listing.
Old Feb 1, 2005 | 05:51 PM
fw190bvi's Avatar
if it was just the speedo, then it could be a vehicle speed sensor, but since the tach isnt working, it its not a fuse, then id assume it could be an issue w/ the ECU (codes or not)
Drola
Sep 14, 2011 07:26 AM
chad
Apr 13, 2009 06:43 PM
chad
Apr 7, 2009 03:04 PM
ri_rv
Apr 22, 2005 08:05 AM
cegleitz
10
Jan 31, 2004 09:39 AM
