Need help with tunning toda spec a's
Old Feb 1, 2005 | 04:46 PM
allmotaR's Avatar
Default Need help with tunning toda spec a's
Searched, nothing found. I have a set of toda spec a's in my 2000 itr, i need to know how many degrees to adjust the cams. I currently am running 2+ on intake and 0 on exhaust. Thanks in advance
Old Feb 1, 2005 | 05:03 PM
JDM978's Avatar
Default Re: Need help with tunning toda spec a's (tyrone biggums)
try asking toda them self they alway answer my answer with good respondes
Old Feb 1, 2005 | 05:05 PM
allmotaR's Avatar
Default Re: Need help with tunning toda spec a's (JDM978)
Oh, thanks. I assume there's a toda toll free#?...also do you know there buiss. hrs.? Thanks
Old Feb 3, 2005 | 05:50 PM
allmotaR's Avatar
anyone?
Old Feb 3, 2005 | 07:45 PM
GeeReg's Avatar
Put it on a dyno to see where it makes more power.....
Old Feb 4, 2005 | 12:57 AM
alfaaay's Avatar
Default Re: Need help with tunning toda spec a's (GeeReg)
Typically you can advance the intake cam and just get more overlap which can be good. +2 intake is actually pretty good until you get it tuned. I've got A's and have them set at +2 in. -1 ex. I'm waiting for a dyno to actually see what happens.
Adding on to this topic (not hijacking haha), I read that Tbone or someone had spec A's set at +5 intake and -1 exhaust when they tuned them. Are cam timing settings usually like that with spec A's?
Old Feb 4, 2005 | 07:37 AM
Black R's Avatar
25 Year Member
Default Re: Need help with tunning toda spec a's (alfaaay)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alfaaay &raquo;</TD></TR><TR><TD CLASS="quote">Typically you can advance the intake cam and just get more overlap which can be good. +2 intake is actually pretty good until you get it tuned. I've got A's and have them set at +2 in. -1 ex. I'm waiting for a dyno to actually see what happens.
Adding on to this topic (not hijacking haha), I read that Tbone or someone had spec A's set at +5 intake and -1 exhaust when they tuned them. Are cam timing settings usually like that with spec A's?</TD></TR></TABLE>
It's different for all motors...
On spec b's, I've gone +15, -10 and got the best power...
Leave the cams at 0,0 until you get it on a dyno...
Old Feb 4, 2005 | 10:56 PM
allmotaR's Avatar
Default Re: Need help with tunning toda spec a's (Black R)
thanks fellas
Old Feb 5, 2005 | 12:03 AM
Mike K's Avatar
out of probably 6 or 7 times that I have tuned spec A's on the dyno... almost all of them have like +4 or +5 on the intake cam.
the exhaust cam was the main variable on all the motors.. but for the intake cam, i can pretty much guarantee you good results at a heavy asvance like 4 or 5.
Old Feb 13, 2005 | 09:32 AM
allmotaR's Avatar
Default Re: Need help with tunning toda spec a's (Mike K)
so it'd be safe to bump the intake up to 5*advanced, off dyno?
Old Feb 13, 2005 | 09:53 AM
Black R's Avatar
25 Year Member
yes.
however, you wil need fuel tuning.....
Old Feb 23, 2005 | 03:10 PM
allmotaR's Avatar
what should the FPR be set at? i have it set @ 42. Thanks
Old Feb 23, 2005 | 03:16 PM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tyrone biggums &raquo;</TD></TR><TR><TD CLASS="quote">what should the FPR be set at? i have it set @ 42. Thanks</TD></TR></TABLE>
Again, you asked about "tuning", but you've made no mention of plans for a trip to the dyno. Without a wide-band O2 and a dyno, you simply have no idea what effects the changes you're making to cam timing and fuel are having on your power curve or your A/F ratio.
k20o2o4civic
Mar 30, 2006 07:53 AM
Grand
May 2, 2005 01:59 AM
bluesaint
Nov 21, 2002 01:22 PM
Down_Und_R
May 28, 2002 04:51 PM
