Curious if some B16 and B18 parts would work on a D16
Old Feb 1, 2005 | 04:22 PM
JRDbuilt's Avatar
Default Curious if some B16 and B18 parts would work on a D16
I have seen some nice parts for the B16's and B18's from companies like spoon, toda , Jun....etc.
would parts like the Hondata Intake gasket work on the D16 car? or a Throttle body?
also what about like spark plug wires with the distributor conversion that seems to be a popular conversion.
thanks and sorry if it's a Noob question.
Old Feb 1, 2005 | 04:55 PM
PrettyLude's Avatar
the intake manifold gasket would not fit, the throttle you can use though
Old Feb 1, 2005 | 06:25 PM
ReV LiMiT's Avatar
Default Re: (PrettyLude)
i heard you can use LS rods in a d16z6.....
Old Feb 1, 2005 | 06:48 PM
StorminMatt's Avatar
Default Re: Curious if some B16 and B18 parts would work on a D16 (JRDbuilt)
Not alot from B-series motors will work on D-series motors. Unlike F-series/H-series/K-motors, B-series and D-series motors don't share alot in common (like bore diameter or bore spacing). In fact, B-series motors are physically quite a bit bigger. So not much will transfer over.
s.cha
Jan 3, 2011 01:44 PM
EJ6JON
May 13, 2009 06:28 AM
