Some Jun 3 questions...
Ok, so I know that Jun 3s are the type of cams that love high compression.. What can I do to get the most power and best performance out of them? What compression would be the best and most beneficial?
I was leaning away from ctr's becuase i heard they get really hot and that makes a bigger chance for detonation. I figured i would be safe with the Jdm itr's and maybee a thinner headgasket.
i hope ur using it as all out race cam cuz jun 3 are horrible for the street. u make ZERO power until around 6.5k+. it is an all out race cam anyways.
JDM ITR pistons are a waste of money IMO.
Man this cam thing is kinda redundent, I think we should keep some posts on top of the board about cams, header, clutch/flywheel. I think if we put these three topics on the top of the board the number of posts would drop greatly
----------------------------m
when swapping piston to higher compression do i need to swap out the piston rod too?? or can i still use the rod with different piston? i'm new at this topic
hooptie157
May 21, 2002 01:41 PM
